^ Pretty much
Thats why I originally didnt say 'this will definetly be it' but it is most likely one of those things. I suppose if you wanted to test the heat exchanger you could remove the coolant lines, link them together and then run the car and see if the problem gets worse, or if you get oil leakage out of the coolant ports in the heat exchanger. Just let the thing warm up easy
Otherwise if its head gasket/head related then the only option is to pull the head off.
  • Like 1
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920489
Well, if you want to look at it that way, then yeah, it is an expensive way to diagnose a problem. But I tend toward the expectation that people on here who ask these questions need a mechanic to do the work, so they will then take it to a mech with the "oil in water" story. Whether the head gasket gets replaced or not would then depend on what the mechanic finds.
But I take your point.
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920541
there is tests you can perform to determine if the hg is blown or not whilst the motor is intact,taking the(factory) hg off usually destroys it and it maybe harrd to pick up where it blew(thats if it blew at all)
its just the way it is
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920628
Over the course of a weeks driving does it use much coolant?
Not the same car, but my Commodore had similar issues after I replaced the radiator and thermostat, new fluid etc.
I swore I'd done the head gasket, as after a few days there was little bits of oily crap on the rubber of the radiator cap. Then I checked the overflow, and it was in there too.
It was using around 100ml of coolant a day.
I found a heater hose that was a bit loose, and then dumped the coolant and replaced it. Its been fine ever since! The only thing I could think of was either the new radiator had a bit of crap in it, and the fresh coolant might have dislodged some buildup from the engine somewhere.
Check the overflow bottle to see if its got the same stuff in it
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920670
(to op 2nd answer above )not time to panic yet strongly suggest you get the engine tested before you start tearing the motor down and then having to work out which TAB you can rob to pay for it :-)
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920679
QUOTE
/QUOTE
Oil in water and combustion gases in water are two separate things though. I don't think there's a "test" that will tell you that your oil in water problem is definitely HG or not.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920688
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
