This is getting really frustrating so im after some opinions on this, i seem to have constant leaks around the plenum gasket and ive tried the stock and at the moment have the cosmetic gasket on.
A few things im not sure about are the actual bolts seem like they bottom out before they really nip up,
the cosmetic gasket is flat and the stock one has a ridge around the cylinder part which maybe is better for sealing, although it seams to squish when trying to really tighten it up.
help please...
https://www.sau.com.au/forums/topic/428353-plenum-leaks/
yeah its a stock plenum, the stock bolts have a unthreaded length on them and i think there bottoming out before its tight enough, but then at the same time im not sure if im over tightening it causing it to push out, ive been spraying it with so much carby cleaner testing it that it might be affecting the gasket now maybe.
should i be using any type of gasket goo/sealent or just gasket by itself?
2 bolts on the outside/fender side keep leaking even after tightening the shit out of them with some different bolts that have thread all the way to the bolt head.
Edited by AngryRB
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6921036
If you think the bolts are bottoming out, couldnt you try shorter bolts? Or space the bolts with a washer or two?
The area that seems to be leaking is where ive replaced the stock bolts, the bolts used have washers on them and nip really tight and still leak, so not sure what to do now.. wonder if the Loctite hardened before it got tightened up the first time and has created some uneven surface between the plenum and gasket..
should i buy a stock gasket and try again?
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6921123
I just opened up a can of worms with this today, after starting it and tightening up the bolts a bit more, sprayed some more carby cleaner and its leaking, closer look and its developed a crack :(
so, can I just have this welded together permanently, is it possible and any issues that would occur doing that?
Edited by AngryRB
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6921622
bit of a dilemma, 3gaskets ive tried now and back to square one, if its possible to get the injectors in once its welded it sure would resolve this constant issue, OEM gasket leaks after some high boost runs and this cosmetic ones leaking without boost.
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6921900
I dont know gtst plenums and the gtr ones use studs. First I would take the plenum off and check the bolt length since you mentioned that. To me, bottomed out bolts feel a bit "springy" when they get tight since you're flexing the entire length of the bolt. Measure the width of the plenum then gently turn the bolts into the head without the plenum in place to check the exposed shaft is shorter than the plenum width. Don't get excited about the exposed shaft! (yes folks, i'm here all week)
If the bolt length is good, then you need to check the mating surfaces are perfectly flat. Its very unlikely the head wont be flat unless there some external damage to it, so concentrate on the manifold. Since yours is already stuffed, i'd get a good second hander and start there (still check it for flatness). A straight edge (aka metal ruler) is usually what you'd use to check for flatness.
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6922411
yeah its the plenum gasket, the OEM one is a thick rubber style gasket, its interesting how the Neo has a different bolt pattern, it looks like maybe the factory had this issue and so they doubled the number of bolts at that side or swapped the configuration around.
so I have two options
1) get another manifold, gasket and try again which ive lost faith in it ever sealing off for long
2) Pay a fabricator to butcher it up around where the fuel rail goes so I can still fit the top feed rail on and weld it solid shut, so 100% leaks gone forever..
number 2 is a PITA and number 1 is 50/50gamble.
Edited by AngryRB
https://www.sau.com.au/forums/topic/428353-plenum-leaks/#findComment-6922867
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
