I have a 1992 RB20DET from a 1992 R-32, no mods that could effect boost - we made a custom intake manifold, but that was strictly for cosmetic reasons. The wastegate controller does not appear to have been tampered with. It goes right up to 11 pounds boost, but never over that.
1. What is the normal max boost pressure on this engine when completely stock?
2. What is the rated horsepower, and at what boost pressure is it measured?
I have done quite a bit of searching, can't find the answer these seemingly simple questions. Anyone here know the answers?
https://www.sau.com.au/forums/topic/428395-rb20-boost-pressure/
I'm not 100% sure, but from what I know, and I'm sure someone else can confirm for me, the stock RB20 wastegate actuator is 10psi and the power an rb20det makes from factory is about 165kw at the flywheel I think?
My stock HCR32 (auto) was on the dyno recently, 117Kw atw, 10psi tapering down to7.5
Wow. That's awful. When I tuned mine, it was an auto ECU but had been converted to a manual box years before. Running 14 psi on the factory tune it did ~150 rwkW (and the dyno is a pretty good one, certainly comparable to most other DDs). Boost would hold up pretty well at high revs. After the ECU was tuned and with boost turned down a little (12-13 psi) because we were at max in a few areas, it was more like 170rwkW.
The only other mods on the car were full exhaust, FMIC and metal turbo inlet.
awful????? going by this converter http://www.mk5cortinaestate.co.uk/calculator4.php and wiki I'm down 12 HP from new :ermm:
anyways 3" turbo back goes on this weekend weather permitting and the following weekend new EV14 injectors then I'm off to the drags
Yuh, awful. Even before I put a boost controller onto my RB20 it would pretty much hold 10 psi up to high revs, and that is where most of your low reading is coming from (assuming no low reading dyno). 7.5 psi boost is soft compared to 10. And as you can see from my report above....14psi makes it a completely different thing. 150rwkW feels drastically different to 117.
Still think you're being a little harsh, 12hp below new running stock everything accept a fuel pump, the only possible issue is a slight exhaust gasket leak which will get confirmed when I put my 3" exhaust in. You don't know your compression test readings for those dyno figures? When I put my injectors in I'll do a compression test.
Thanks for the replies - that takes away the mystery somewhat. I have owned a lot of cars, but this is my first experience with a turbo. As I stated before, the purpose of the custom intake was purely cosmetic - to get rid of all the clutter on top of the motor. I already described this here:
http://www.skylinesaustralia.com/forums/topic/428272-not-living-in-oz-but-one-of-the-other-colonies/
Edited by stilettoman
R33's and 34's were 7.
Stock exhaust will probably be the culprit of this. Almost everyone makes 10-11 PSI for the full range with their R32 because almost everyone has a aftermarket exhaust. The dyno wasn't particularly low reading as far as i know, 3 r33's on the day all made within 1-2kw's of 180 with only an exhaust and a front mount, and my tuned r32 with 33 turbo mad 170kw's.
Dam 33's.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
