Deadlift
60kg x 10
80kg x 5
100kg x 1
120kg x 0
115kg x 1
100kg x 4
100kg x 4
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 1
55kg x 0
52.5kg x 1
45kg x 6
Starting to get pretty depressed with the lack of progress on deadlift and bench
15/07/14
Deadlift
60kg x 10
80kg x 5
100kg x 1
120kg x 0
115kg x 1
100kg x 4
100kg x 4
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 1
55kg x 0
52.5kg x 1
45kg x 6
What does your gym think about your workout vs progress? do they have any suggestions that may help?
My gym agrees I should be lifting heavier and have given me lots of suggestions and advice, such as box squats, resistance band bench, incline bench, floor press, good mornings and other things but trainer says no.
That is unfortunate that your trainer won't allow it, for whatever reason it is. You've persisted with this method for a long time now.
Maybe the minimalist approach isn't enough for you.
Emulate the strong to get stronger.
Her routine is fine and still presenting gains; going very well considering how little time is spent working out and no assistance exercises; she is on a little plateau for 1RMs and I wouldn't even call it that, given progress is still being made in volume weights and reps when it's not being made with 1RMs. Read the rest of the thread and you'll see the steady increases leading up until the last week or so.
It's nothing but impatience from someone who skips dinner and wonders why the lifts aren't there the next day.
I skipped dinner one time because it was fking horrible and I couldnt be bothered making anything else as it was late so I had a protein shake. I eat a meal before gym which is dinner anyway. I eat nearly 2000 calories a day so I'm hardly under nourished.
Edited by L33SH
17/07/14
Squat
20kg x 5
40kg x 5
50kg x 3
60kg x 1
65kg x 1
70kg x 1
75kg x 0
Bench Press
20kg x 5
30kg x 5
40kg x 3
45kg x 1
50kg x 1
52.5kg x 1
Deadlift
60kg x 5
80kg x 3
100kg x 1
110kg x 1
115kg x 1
120kg x 1
Seemingly angry post precedes successful lifts that were failed last time haha
A thought on your training. 1rm's get more taxing the heavier the weight. Is this affecting your recovery?
Funny that, she ate a solid dinner lastnight and listened to my training lol
This was actually a training prep/test for a novice lifting comp on Sunday. So squats were well past parallel, deadlifts without hitching and bench was done with a pause at the chest and me giving the go ahead to "press". She did very well and only missed one lift, which is great considering there was hardly any rest between lift attempts (we got all this done in under an hour).
I never said it's not working.
I said maybe the minimalist approach isn't enough.
23/07/14
Squat
20kg x 10
40kg x 10
50kg x 5
60kg x 5
60kg x 5
60kg x 5
50kg x 5
40kg x 10
Focused on depth rather than weight
Pull-Up
5
4
4
4
Decline Ab Crunch 10kg plate
10
10
10
So sore, especially my back and hip flexors. I think it's from lifting all day Sunday, then going straight on a plane for 4 hours and getting cramps then driving for 2 hours.
  • 3 weeks later...
11/08/14
Squat
20kg x 10
40kg x 5
50kg x 3
60kg x 1
65kg x 1
70kg x 0
60kg x 5
60kg x 5
60kg x 5
50kg x 5
50kg x 5
50kg x 5
50kg x 5
Pull-up
4
3
3
3
Lat Pull-down
30kg x 10
40kg x 10
45kg x 5
50kg x 5
Seated Row
20kg x 10
30kg x 10
35kg x 10
25
25
25
10
10
10
14/08/14
Deadlift
60kg x 10
80kg x 6
100kg x 1
110kg x 1
100kg x 1
80kg x 10
80kg x 5
Bench Press
20kg x 10
30kg x 5
40kg x 3
50kg x 1
45kg x 6
40kg x 10
30kg x 15
Bicep Curl
15kg x 10
17.5kg x 10
20kg x 10
20kg x 5
20kg x 5
20kg x 4
Decline Ab Crunch 10kg Plate
50
16/08/14
Squat
20kg x 10
40kg x 5
50kg x 3
60kg x 3
70kg x 1
60kg x 5
60kg x 5
60kg x 5
60kg x 5
50kg x 10
40kg x 10
Pull-Up
4
4
4
3
3
2
Lat Pulldown
30kg x 10
40kg x 10
50kg x 10
Captain's Chair
25
25
25
25
18/08/14
Squat
20kg x 10
40kg x 5
50kg x 3
60kg x 3
65kg x 1
70kg x 1
65kg x 1
60kg x 5
60kg x 5
60kg x 5
60kg x 5
60kg x 5
50kg x 10
50kg x 10
40kg x 10
Pull-Up
4
4
3
3
Lat Pulldown
30kg x 10
40kg x 10
45kg x 5
50kg x 5
Seated Row
20kg x 10
30kg x 10
40kg x 5
40kg x 5
30
30
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
