You weren't happy with your stomach before either...you wanted visible ab definition.
Nothing to do with cardio, it's purely body fat, which is why skinny guys can have skinny man six packs that show definition (however flat). A lot harder to achieve in girls, even skinny, because of the naturally higher body fat percentage and men having much more muscle there and potential for that muscle to begin with. This is why you have to ignore a lack of definition until you're finished bulking and building up muscle, then can go on a cut to reveal it.
Like me, you're naturaly a sleight build. At 60kg now you're actually far from what we would consider bulking anyway. Consider your back definition in the above photo. Your body fat currently is what I'd call a healthy maintenance. You could easily add more calories for a greater surplus and gym energy boost without looking fat. 65kg wouldn't be unreasonable to be carrying around and you would still look far from what anyone would consider fat.
That 50 x 30 was a tyrannosauric effort and the best squatting I've seen from Leesh; all nice and deep squats using the elasticity of the ass the ground squat to keep momentum and an explosive action. Somewhere between the missed 1RM and the 60kg sets we had a pep talk that really flicked on the intensity switch and proved once again how much of a part attitude and mentality play in this stuff. Very happy with the efforts tonight after a dismal start.
  • Like 1
Thanks Birds.
I definitely let outside influences into the gym, which I need to not do in future. With my life so out of my comfort zone right now, the gym is the one constant I have; something I can be in control of. When I missed the 75kg that I've gotten many times before I gave up. I even said I'm not squatting anymore. I lost all intensity, motivation and drive.
I'm lucky that my gym partner is also my emotional trigger, the one person that can get me out of my negative mindset and thoughts, and push me just enough to bring me back to where I need to be. He helped me flick the switch and turn off my negative thoughts and reminded me why I'm doing this.
I'm proud of myself for having the inner strength to turn my session around and achieve a pb of 30x50 and I'm thankful to my partner for believing in me.
Bring on 80kg squat.
  • Like 2
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
