Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 2
60kg x 2
60kg x 2
55kg x 3
50kg x 4
50kg x 7
45kg x 12
Deadlift
40kg x 10
60kg x 10
80kg x 5
60kg x 10
60kg x 10
60kg x 10
Bicep Curl
20kg x 10
25kg x 8
30kg x 3
25kg x 5
20kg x 10
20kg x 10
23/11/15
Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 1
60kg x 1
60kg x 1
55kg x 2
50kg x 9
50kg x 6
45kg x 10
40kg x 10 (close grip)
Deadlift
40kg x 10
60kg x 10
80kg x 5
Bicep Curl
20kg x 10
25kg x 6
30kg x 3
25kg x 5
20kg x 10
20kg x 10
Yep hence the strength decrease
She's down to 61.5kg body weight
60 is the goal before the end of the year - can be done easily by not eating, but we're trying to maintain as much strength and muscle as possible so it's a slow process. No calorie counting though, I've taken all junk foods out of her diet and introduced a little HIIT.
I'm cutting a bit myself for summer and it's really fking with my own strength - bench press has dropped by 5kg :(
  • Like 1
I was ~81kg ~11% but got on a bulk to build more muscle especially my legs...peaked at 92kg and now at 88...another 3kg would have me fairly lean again
I'm finding this myself and my legs aren't even big
Forget about jeans, I can't even bend my legs in them
This is in thanks to my big ass from all the ATG squats I've done over the years...
I get in the car with jeans on and I know I have a plumbers crack going on
Worse, I have a long torso at the abdomen and a thin waist so any pants that do fit either look too big on my waist or tight on my legs
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
