EPIC FAIL !!!
Due to Technical issues with Richard's 34, we were too busy Trouble Shooting to get out there.
So Sorry to anyone who showed and got the dissapointment. :(
  • 3 weeks later...
I believe we have an SAU NSW cruise coming up.
Will try post the details for you guys soon.
Are their cruises around Sydney or do they head towards the Canberra sides of things?
edit: cruising around the Blue Mountains might be a good middle meet place and some curvy roads up the Blue.
Edited by RosieR34
We are doing cruises up north in Newcastle/Hunter area and the Sydney guys are doing their areas like Mac Pass and stuff.... We are hoping to combine and all meet up sometime soon so we can put some names to faces etc ;)
Oh, as long as someone brings jumper cables for Rob :ph34r:
Mat, with all due Respect my fine Friend...
f**k you.
:P
All sounds good to me. :thumbsup:
So not this weekend but... soooon.
f**k you.
:P
:rofl:
Will never live it down.... Bloody Mani!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
