hi, hope it hasnt been covered before (cowers) simple question, can r33 rb25detpistons be used with a r34 neo head? ive noticed that the r34 pistons have valve reliefs so im bit concerned about piston to valve clearence and an increase in compression? thoughts? comments ? (no nasty ones please)
https://www.sau.com.au/forums/topic/428525-r33-pistons/
thanks guys, youve given me a bit to think about
. . picked up a 34det neo dirt cheap and (also havea 33 bottom end) it has a damaged #3 cylinder and just working out my options for using what i got
it had swallowed a small bolt which made it run on 5 and the guy who owned the car drove it for three months like that. .
https://www.sau.com.au/forums/topic/428525-r33-pistons/#findComment-6925634
Use the Neo bottom end. Buy pistons. Sell R33 stuff to someone else. Profit.
wildo that , originally was told number 3 was dead and was (possible detonation damage) cos the owner was running it on 91 ulp
owner needs shooting as this motor still has factory hone marks on the bores
if anyone here has some low k (stock size) 34 pistons in good condition please pm me as the internals of this motor are in otherwise mint condition and wouldnt take much to get it going again
https://www.sau.com.au/forums/topic/428525-r33-pistons/#findComment-6925674
Neos use RB26 rods, which are a different length to older 25 rods (I'm pretty sure....).
Nope.
RB25 non NEO and NEO and RB26 share the same con rod length.
NEO uses the same 'stronger' rod as the 26 though.
OP - I have a full set of 34 NEO pistons and rods in excellent nic for sale, unless Simon still wants them?
https://www.sau.com.au/forums/topic/428525-r33-pistons/#findComment-6925894
kitto beat me to it.
neo rods same length as non neo. As is the pin height on the pistons. in fact the neo piston and non neo piston share all the same dimensions but the neo piston has more cooling passages under it where oil is squirted. its probably lighter also but need to weigh some to confirm.
the difference in compression is all in the head.
https://www.sau.com.au/forums/topic/428525-r33-pistons/#findComment-6929275
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
