  • Replies 48
  • 1 month later...
I pmed you twice about three parts i was interested in. Got no reply. Keep scratching my head as why i didnt get a reply. Only thing that makes sense is ur inbox is full or u didnt get my messages somehow....
Hey mate do you have the drivers side guard inner and also the bottom stone guard that covers the bottom of the engine?? With the ducts that flow to the brakes etc and factory suspension?
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
