Hi boys,
Hope someone can shed some light to what happen tonight.
Driving home tonight and at the lights had a bit of a squirt so I could jump in merging lane and all of a sudden revs cutting down and engine light on???
Pulled over quickly turned the car off and after few minutes started again with same thing not going over 2K revsmwith engine light on?
Lucky only 500 meters from home drove very slow. I"m now one very concerned Stagea owner.
Any input or where should I start looking is much appreciated.
Thanks
Dave
https://www.sau.com.au/forums/topic/428813-m35-problem/
So when you said died no cleaning will help? Also where to get new one as I would imagine second hand would be a waste of money?
After I replace it how do I get the engine light not to be on or will it clear itself?
Thanks everyone for posting reply!
Cheers
Dave
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6931916
There was an RB26 AFM fix in the DIY section - basically some of the soldered joints go dry, so you just reheat the solder to make it "take" again. You pop a cap off the compartment where the plug is, and check the pins that run from the plug to the PCB. You should be able to see dry solder joints with magnifying glass, or just re-do all of them anyway. No idea if the VQ AFMs are similar, and of course it could be some other problem.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6931931
VQ ones aren't similar and can't be repaired. It seems the processor on the board inside the afm stuffs up, it will require replacement.
The main issue is the original part has been superseded, and the new AFM Nissan supply doesn't seem to last long. Your original one has lasted 13 odd years, these are lasting 4 months if you are lucky. Nissan don't want to warrant them either, and at a cost of $350 each... My suggestion it to try and find a second hand one for now until I sort out an aftermarket alternative for us to use, at 1/4 the price, then keep it in your glove box. ;)
Our original Nissan p/n is 22680-6N211 and the new Nissan p/n is 22680-6N21A.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932175
full
Thanks Scotty as usual always helpfull, What would we do without you.
Cheers
Dave
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932230
Regarding our chat the other day Scotty, apologies for not sending the link.
Here is the one that I purchased; Part number on my unit is exactly the same as the one pictured.
http://www.ebay.com.au/itm/290794600600
As Scotty says, I had a brand new, OEM replacement (new P/N) fail in less than 3 weeks. Hit the key one morning, pop; dead.
Super pissed of would be an understatement. :rant:
The ebay replacement is working fine; and arrived very quickly. Has been in for a bit over 3 months according to my records.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932250
Hey Scotty, I was thinking of sending one to my contacts in China to see if they could get it manufactured for a couple of dollars. Would need to buy a few thousand, but if everyone bought 5 or 6 they get used up pretty quickly. It wouldn't matter if they lasted 6-12 months either, if they were that cheap (change with the oil, lol)
However, the risk is they could be as bad as the Nissan ones & then we'd all be annoyed, even if they only cost 5 bucks.
Hey Dale, keep us posted on your experience with the Ebay one. Maybe we could do a deal with that guy for a bulk order?
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932317
That is the path I was going down Leon, but I wanted to check the quality and test the airflow map. As Dale is running a Chinese one I assume they work well, as long as they are all coming out of the same factory... And I bet that's the same factory Nissan buy from.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932337
No luck with second hand unit so it's either nissan for $318 ex Melbourne or e-bay for $99 or I can get just the sensor from Amayama for 106 bucks?
The question is which one will last the longest??? or will the sensor be enough or do I need the whole unit?
Anyone.....
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932596
Anyone.....
just the sensor, I've gone thru 4 of them, once done keep it clean. Touch would. Also what filter do you have I've had k&n and was nothing but trouble, paper is the best:)
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932684
The sensor is all you need to replace, the tube is just a plastic tube.
The Amayama one 'should' come with a 12 month warranty. Best to speak to them about it before purchase. They are known to last anything from 1 second to 4-6 months. Like I said, I wouldn't be buying one.
The second hand one can come from many different cars, eg Maxima, Xtrail, Pulsar, if you google search the part number you will soon realise they are all similar just with different numbers. Even VW and Merc ones look the same with a different plug. How long it lasts is anyone's guess.
I would just buy the ebay one in the link provided for now and try it out. There are a few guys running them without issue, I just wanted to check how accurate the air temp sensor was to ascertain the quality first. I will probably place a large order directly from China to bring the costs down for us all, and allowing us to afford a spare for the glovebox.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932715
I've got "blitz" panel i the air box but I'll take into account as I have paper one as well
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932721
You guys getting early failure on new AFMs should talk to Fair Trading or the equivalent in your state. In NSW Nissan cant get away with saying there's no warrantee since its mandatory under the law to supply goods of "merchantable" quality.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932771
I'd imagine they're going down the "part is being damaged by a fault on the vehicle" if the one on the car fails, then the replacement fails, they'd be arguing that an issue on the car is making the component fail.
https://www.sau.com.au/forums/topic/428813-m35-problem/#findComment-6932871
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
