nah stock boost is 5 - 7psi..
when you go past 4500rpm the boost solenoid thing opens and gives you the extra 2 psi.. so you get 7 in total..
What do you mean 1+ ?
7 on the stock boost gauge means 14psi if thats what your talking bout ?
r34 stock boost gauges go from 0 to -700 and up to +1 on the gauge, anyway i guess its a safe mod to do that wont damage the turbo.
Whats +1kg/cm in psi?
Edited by RyanN
1kgcm2 is 1bar which is 14psi. this will fry your turbo. max you should be running should be 11/12 psi as this is border line. the heat from runing that much boost will fry the exhaust wheel
ok, wasn't sure if this mod was damaging the turbo or not, as i dont exactly want to blow the thing yet :P
Before the mod the gauge would go just below the halfway mark and after, just above it; that would be around the 7-8psi mark?
Its the pressure that shatters the turbine wheel right not the heat?
Edited by RyanN
hey paul.......i thought .8 bar was around 9-10psi.....is it in fact 11-12 psi? i remember from the discussion over on skylineowners.com that all the guys said not to run more than .8 bar b/c that's the max you can safely run the stock turbo at
Late,
Daniel
sorry my grammar kinda made my statement a bit strange. here's what i really meant
max you should be running should be 11/12 psi as this is border line. the heat from runing that much boost will fry the exhaust wheel.
yes 0.80 is approx 12psi. i run 0.85 daily and its on border line of frying it and it doesnt make any more power past this level either, but stacks more heat, which is the killer
9psi is around 0.65 bar
Hey guys, im another proud R33 GTSt (series II) owner! My R33 is completly stock besides the K&N pannel filter... Can some please either email me or post up some pics showing the factory boost solenoid?
Thanks
Thanks
Heres a pic of one:
http://bur.st/~rinmak/r33/IM001060.JPG
Its the silver thing with one pipe coming off of it and an empty nipple beneath that.
Yours probably wont have an empty nipple though :D
each psi is a noticable gain however you should make sure you have a good exhaust and fmic before running that much pressure
i'm hoping to be able to get my downpipe and de-cat pipe done this thursday (already have an 80mm cat-back on the car)
and my friend is going to give me this MASSIVE Calsonic SMIC (over 6 inch thick core)......I think that core will be good up to 300whp
Late,
Daniel
Hey guys,, just did this mod and am confused as to what my stock boost gauge should read,, The solenoid is operating (I put in a switch,, but the boost gauge only gos to .35,,is that right? I thought I should get more than that,, car is completely stock except for 3 inch high flow cat and nismo exhaust,, Is there something wrong or is that all I can expect without spending some coin?
cheers,
John
John, the boost gauge that is in your OEM gauge cluster should be reading half way above the half way mark on the gauge which works out to .7 bar or about 9psi of boost.......if its still only reading half way below the half way mark (when below 4500RPMs) then you're running .5 bar or about 7psi of boost
hope that makes some sense :D
Late,
Daniel
hope that makes some sense :)
Late,
Daniel
Thanks Daniel,, I bypassed the controller and it spiked (just after the computer confused itself and then re-mapped of course) so I put the controller back into the loop,, it still only goes to right on half way, so I'm guessing that either the gauge is dodgey or the actuator is not quite right,, might just make up a bleed valve and have a play,,
cheers
John
no problem John :D if you were running high boost (.7 bar) you would DEFINITELY notice the difference in the lower RPMs when compared to .5 bar at the lower RPMs :)
what i did was peel back some of the insulation on the black ground wire, spread the core apart in the middle and looped a my additional ground wire through there, I then soldered the wires together, taped them up nice and tight, and proceeded to wrap the other end of my ground wire around the bolt that hold the power steering reservoir bracket onto the shock tower
i hope this helps.......if it make sense :)
if not i can try and take a picture of my solenoid and wiring as it stands now later on today or tomorrow
Late,
Daniel
Hey Guys, you think by running a direct ground signal to the earthwire of the boost solenoid while its still connected to the ECU will damage the ECU??? cause thats what i thought about doing as well as adding a switch but was worried about damaging my ECU.
Regards,
Sarkis
Alright guys, i finally had the time to do this little mod on my R33 S2 and it works! i noticed my rev range being more smooth and more comfortable without that nudge you feel at 4500rpm... you can see full boost comming on as low as 2500rpm (little over the halfway mark on the factory guage) acceleration wise i noticed a little increase but nothing too drastic, perhaps its cause i still got a stock exhaust???
i managed to find a way to wire up this mod up without any cutting or soldering! i used the airbox bolt for my earth and fed the wire into the harness as shown in the pics... this way you can remove the mod and everything is still original!
Nice find paul!
Regards,
Sarkis
no problem John :)  if you were running high boost (.7 bar) you would DEFINITELY notice the difference in the lower RPMs when compared to .5 bar at the lower RPMs :)
Late,
Daniel
Thanks Daniel,, I did put a switch in and wired it to the power steering mount bolt, then I taped it all to the harness so that you can only just see the switch hiding behind the air box,,
I will endevour to play around with some sort of bleed valve arrangement and wire in a relay so that it can be switched from factory boost controlled,,to factory maximum boost and also to have a bleed valve arrangement as well (three way switch),,,I will post the results when I'm done,,,
cheers
John
I just dyno'd my car with this mod, except when I put this mod on I put a on/off switch for it, the difference between ECU relating boost at low revs, and earthing the wire seamed to be nothing at all!
Saying that I swear it made a difference when I did this before I dyno'd it!
I'm at a small loss now, if you put a couple of washers under the wastegate actuator mount points it increases boost BTW, not the best tho, my fuiel cut defended cut in and shut the car down for %60 of the rev range, when it was boosting hard tho, it was f**kING HARD
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
