thanks for this mode:) its working i jast change graunding place :laugh: now in second gear shows -8 PSI:) thanks again
Edited by guricha
hey all,
the idea of the switch is a good idea to control when you want highboost or when u want two stage boost.
ANYONE got pics of their switch, or installation of the switch that they could post up.
assuming you cut the black wire and ground it, without using a switch.
just a quick question?
is this mod reversible? like if u want the two stage boost again without using a switch. further down the track could u reattach/solder the black wire through its original path again? or is stuffed once cut?
hopefully someone can help?
Cheers :laugh:
Edited by R33LIN
hey all,
Cheers :laugh:
I would imagine that you could solder the wire again, I just bought a 4 buck switch from supercheap, and mounted it in the dash I drilled a hole in the removable pushout panel thing, its just a simple on off switch,
I cbf running the wire through the firewall so i ran it next to the loom that follows the strut and continues to the wiper motor, then into the gaurd and the door, i know crap way of doing it but it works, BTW heres a pic or two! :)
Just did this on my R34 this afternoon, it works..it's now hitting 8psi at about 2,500rpm.
Will be hooking up a switch next weekend to switch between high boost & low/hi boost.
Also, in the pic it looks like the black wire to the plug is still connected but it's not - it's just tucked back into the black surround.
Question:When I put on a full turbo back 3 inch exhaust this will be rendered unnecessary, correct?
Edited by so_tred
Hi all. Is there anyone from sydney who has done this mod that wouldnt mind helpingme out. i live in the liverpool area and dont feel confident enough to start cutting wires. let me know.....there will be an ice cold six pack in it.
No. The only time it will be unnecessary is when you have some form of boost controller that will be bypassing the stock solenoid.
drive to Turramurra and ill do it for you :(
Im outta switches though...
Seriously man... its the most simple job ever...
I just shoved a cotter pin down the back of the plug.. and grounded it to the airbox.. I can remove the mod within seconds and no cutting wires at all
I thought if the boost solenoid was left standard and I added a full exhaust which usually will up the boost by 2psi then the solenoid would be made obsolete?
no, instead of being 5psi/7psi (on an R33, not sure if its the same boost on R34's?) it will then be 7psi/9psi
I hoped it would be like that :P
So it's been tried & proven to be that way?
As far as im aware.. my exhaust is only catback.. However im running around 9.5 PSI... Blitz Turbo timer tell me 0.71 kg/cm2 (which equals 9.5psi) and just installed a boost gauge.. it also reads just under 10 psi
Is that possible with only catback?
Before the mod it was 7/9psi
hey i did this on my 33gtst and its poping and crap well by the way its a S1 4 speed auto , 600x300x75 intercooler and a 3.5inch stainless from cat back and i did this thing by cut the black wire and the black wire onto the car body and the black wire from the computer taped to block it . now took it up the street and it will get to 5 psi then it will just back fire and pop and jump or what ever eles .. then i put it all back to normal then it was fine . i wanted to do this thing , but can anyone tell me how to solve this problem . or anyone from lismore or ballina . cheers, adam
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
