My baby is for sale:
1999 R34 GTR V-Spec - 53,000kms - $55,000 ono.
Located in Newcastle, NSW. Serviced every 5,000kms.
Makes approximately 300kw at all four wheels, and perfectly suitable for a daily driver or track car - mod list below.
Contact me for any further information.
R34 N1 ENGINE BLOCK
R34 N1 TURBOS
NISMO LEADING METAL SET
TOMEI OIL GALLERY RESTRICTOR
TOMEI COMBINATION METAL GASKET KIT
TOMEI CON ROD BOLT SET
TOMEI OIL PAN BAFFLE
NISMO reinforced timing belt
REIMAX IN264 8.58 REIMAX EX256 8.28 CAMSHAFTS
REIMAX CAM TIMING GEARS
HKS ACTUATORS
NISMO strengthen engine mount
NISMO OIL separator
NISMO large capacity fuel pump
NISMO 550cc injector
APEXI SUPER SUCTION KIT
APEXI METAL CAT
APEXI ELECTRONIC CONTROL VALVE
REIMAX pipe Front (isometric type)
AUTO SELECT TITANIUM MUFFLER
HKS HARD PIPE KIT
HKS 15-stage oil cooler KIT
APEXI 3 layer RADIATOR
EXEDY TWIN PLATE CLUTCH
NISMO transmission mount
APEXI N1 Coilovers
NISMO F & R Stabilizer
CUSCO MASTER CYLINDER STOPPER
APEXI Power FC D JETRO
APEXI AVC-R ELECTRONIC BOOST CONTROLLER
Defi BF OIL PRESSURE 60MM & CONTROL UNIT
NISMO FULL BODY KIT
Rays Nismo LMGT4 19 x 10.5 wheels
DBA slotted rotors
Carbon fibre wing blade
CLIFFORD security system
https://www.sau.com.au/forums/topic/429075-fs-r34-gtr-v-spec/
Very nice car mate, great mods on there... i think i spotted you yesterday morning on newcastle road?
Just curious when this was imported and if you have any papers to go with it?
Thanks mate, it may have been me.
I've owned the car for 5 years now and bought it from a member of the forums who had imported it but needed to sell it for capital towards his business.
Bascially he imported it, had it complied and then sold it to me without really owning it for long.
So unfortunately I don't have the original import papers or documentation.
Car has been trouble free for the duration I've owned it, with regular maintenance and the only major changes I made were the addtion of the rims which I imported new directly from Nismo Japan and (385mm front) brake rotors and smaller rears to match.
Sounds good.
More curious atm... seems like a great buy if its in similar condition to mine which has a little less kms, probably looking to get mine to something like this... would love to buy it and mix and match parts then sell one off in stock form etc... but funds dont really allow it atm but may know some ppl who would be interested....
Cheers
Some more info and pics:
I'm the first owner of this 1999 R34 GTR Vspec for the last 5 years since it was imported. Always garaged and regularly serviced every 5,000kms, the strengthened N1 engine has travelled a mere 53,000kms.
Selling as I no longer have the time to enjoy such an iconic driver’s car, but the limited time I drive the car, it never fails to bring a smile from the experience.
Making approximately 300kw at all four wheels, it is perfectly suitable as a daily driver or track car.
Majority of modifications carried out prior to arrival in Australia, I have only added the wheels (imported new directly from Nismo Japan), brakes and other minor items to enhance the look and feel of the car.
Happy for prospective buyers to carry out any third party inspections, car interior and exterior is in excellent condition and a definite head turner with the rare Nismo wheels contrasting the black paintwork.
I’m in no rush to sell the car and although the price is negotiable, lowball offers will be ignored. Interstate buyers welcome.
Few other mods and inclusions not mentioned in the first post:
Apexi Exhaust Control Valve
HKS Circle Earth Kit
Yellow Jacket Coils
BA 5000 383mm F & Slotted R Rotors
Factory HID Xenon Headlights
Factory Floormats
Pioneer Bluetooth Stereo
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
