Just putting this out there in case anyone is selling their R34/Stagea auto after a manual conversion:
Looking to buy a fully built Tiptronic auto gearbox to suit an R34 GTT (RB25DET Neo, 1998 model):
  • RE4R01B Tiptronic gearbox
  • Must be built to handle at least 300 rwkw
  • Stage 2 shift kit (MV Auto, KEAS or equivalent)
  • 2nd gear billet servo
  • New clutches/bands and solenoids
  • High stall (optional)
  • Trans cooler (optional)
The box must be built by an auto specialist and come with a receipt with full specifications.
Let me know how many kms on the box all up & since rebuild.
Recent build preferred (2012/2013) and not really interested in anything from a write-off.
Looking in VIC at this stage for easier inspection and pickup.
PM me what you've got & where, reason for sale, and what you're after for it.
Thanks!
Hahahah good luck mate. The RE4RO1B is the same auto in the V35 250GT. I just had my valve body done. Its not a common box so i doubt there is one out there mate but i wish you all the best. Trying ringing MV automatics in SA
Yeah I realise that :) Been in touch with MV auto in the past, a full rebuild with goodies is pricey.
  • 5 months later...
  • 11 months later...
did you end up finding one?
im after one too
Hey mate, no I didn't so went with a manual conversion instead.
Which means that my auto box is for sale cheap if you're keen, in Vic: http://www.sau.com.au/forums/topic/444714-fs-r34-gtt-automatic-gearbox-and-parts-mbc-fuel-pump-tension-rods-manual-parts-mel/
Edited by V28VX37
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
