Just putting this out there in case anyone is selling their R34/Stagea auto after a manual conversion:
Looking to buy a fully built Tiptronic auto gearbox to suit an R34 GTT (RB25DET Neo, 1998 model):
  • RE4R01B Tiptronic gearbox
  • Must be built to handle at least 300 rwkw
  • Stage 2 shift kit (MV Auto, KEAS or equivalent)
  • 2nd gear billet servo
  • New clutches/bands and solenoids
  • High stall (optional)
  • Trans cooler (optional)
The box must be built by an auto specialist and come with a receipt with full specifications.
Let me know how many kms on the box all up & since rebuild.
Recent build preferred (2012/2013) and not really interested in anything from a write-off.
Looking in VIC at this stage for easier inspection and pickup.
PM me what you've got & where, reason for sale, and what you're after for it.
Thanks!
Hahahah good luck mate. The RE4RO1B is the same auto in the V35 250GT. I just had my valve body done. Its not a common box so i doubt there is one out there mate but i wish you all the best. Trying ringing MV automatics in SA
Yeah I realise that :) Been in touch with MV auto in the past, a full rebuild with goodies is pricey.
  • 5 months later...
  • 11 months later...
did you end up finding one?
im after one too
Hey mate, no I didn't so went with a manual conversion instead.
Which means that my auto box is for sale cheap if you're keen, in Vic: http://www.sau.com.au/forums/topic/444714-fs-r34-gtt-automatic-gearbox-and-parts-mbc-fuel-pump-tension-rods-manual-parts-mel/
Edited by V28VX37
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
