Hks 2530's running 20 psi.
Can't get my car to boost cleanly throughout the gears , and i have no idea why.
When i run 16 psi or 1 bar, no problems. As soon as I flick my eboost street to my other setting (20psi) it does this...
Does anyone have any ideas or solutions? Workshop is telling me that i need new actuators... All pipes are tight, no leaks whatsoever.
Runs like a champ on 16psi, but cant get it to run properly or boost properly on 20 psi. Keeps giving me that flick back
Any feedback or advice greatly appreciated. Cheers
Edited by drgtr7
  • 6 months later...
  • 4 months later...
Hey peter.
Nah still got it capped at 7k and the occasional 7.5. I really want a midrange street car. Hopefully my next retune with e85 should see that. Lol he can drive my car, but then i'll drive his :P
  • Like 1
Hey peter.
LOL Thats why im taking my time putting it back together again, cant trust both of you buggers. :)
Yes, I was using hks intake pipes. My turbo's didn't like them. It would cause them to stall/shuffle. Went back to standard got a retune. Never had another issue again.
the irony that the HKS turbos didn't like the HKS intake pipes...
and all for HKS price too :P
However, I wouldn't be surprised if it wasn't something tune related that wasn't solved upon the retune?
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
