Hks 2530's running 20 psi.
Can't get my car to boost cleanly throughout the gears , and i have no idea why.
When i run 16 psi or 1 bar, no problems. As soon as I flick my eboost street to my other setting (20psi) it does this...
Does anyone have any ideas or solutions? Workshop is telling me that i need new actuators... All pipes are tight, no leaks whatsoever.
Runs like a champ on 16psi, but cant get it to run properly or boost properly on 20 psi. Keeps giving me that flick back
Any feedback or advice greatly appreciated. Cheers
Edited by drgtr7
  • 6 months later...
  • 4 months later...
Hey peter.
Nah still got it capped at 7k and the occasional 7.5. I really want a midrange street car. Hopefully my next retune with e85 should see that. Lol he can drive my car, but then i'll drive his :P
  • Like 1
Hey peter.
LOL Thats why im taking my time putting it back together again, cant trust both of you buggers. :)
Yes, I was using hks intake pipes. My turbo's didn't like them. It would cause them to stall/shuffle. Went back to standard got a retune. Never had another issue again.
the irony that the HKS turbos didn't like the HKS intake pipes...
and all for HKS price too :P
However, I wouldn't be surprised if it wasn't something tune related that wasn't solved upon the retune?
