And
A 10 Tenths Racing pack, to the value of almost $200 to the top 3 competitors! :woot: :woot::woot:
Proudly Presents:
Import Monster SAU-Vic Deca Motorkhana ROUND 3 of the 2013 CHAMPIONSHIP
When : Saturday 31st August 2013 (7:30am)
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $95 non members $85 members
Max Entries: 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplementary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
Please re-read the supplementary regulations before entering the event.
Entry Form & Supp. Regs: HERE
Event Schedule:
Results:
ENTRY FORM IS REQUIRED TO BE PUT ONTO THE LIST. PAYMENT IS REQUIRED TO STAY ON THE LIST.
PLEASE FILL OUT FORM COMPLETELY AND CLEARLY.
- if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'.
- All withdrawals will be refunded after the event. Refunds will not be given after 5pm Monday 25th of August.
- Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
- A reminder that anyone who does not have a licence (Cams or AASA) must bring with them, filled out and with $50 correct change, this form:
AASA LICENCE FORM
- GATES WILL BE OPEN AT 730AM. Given the amount of new people can everyone try to be at deca at 0730. The morning sessions are quite long so the earlier we get going, the more time we have for battles in the arvo.
- Grouping requests: If you have anyone that you would like to be grouped with send me a PM and i will try to accommodate.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
Entrant # Name Car
1. Import Monster
2. Import Monster
3. Leon Stapley 180sx
4. Ryan Bell R35 GTR
5. Ferne Smyth FTO
6. Jake (mike) Lowry S14
7. Juliette Remfrey BRZ
8. Russell Cunningham Sil80
9. Ben Felgate S14
10. Simon Henman R33 GTS-t
11. Brad Archbold EVO 8
12. Jett Benson 180sx
13. Paul Stephenson R32 GTR
14. Ekat EVO 7
15. LLoyd Waldrow XR6T
16. Paul Morris BRZ
17. Rebecca Raphael Corolla
18. Adam Crocitti S13
19. Luke Schulze R33 GTS-t
20. Michael Bourke Commo
21. Min Chan Elise
22. Chris Taylor cressida
23. Kieran Robinson Sil80
24. Tim Watson 86
25. Josh Hindle 180sx
26. Huy Tran Stage
27. Daniel Jones Reliant Robin
28. Jacqueline Sant Sil
29. Robert Chen 86
30. M.Mahmoud? R33 GTS
31. Mathew Hindle Reebok
32. William Chu MX5
33. James McMahon S15
34. Andrew Hindle 180sx
35. Linh Dang 86
36. Peter Pham 86
37. Zhi-yong Lee M3
38. Darren Lang 86
39. Hieu Nguyen 86
40. Jimmy Chin BRZ
41. Chris Wilshire XR5
42. Thang Ngo 86
43. Marrrrk Ryan R33 GTS-t-odore
44. Robert Amenta R33
45. Matt Femino Sil80
46. Dean Course R33 GTS-t
47. Scramble shrrooobbbrrroookkk Big Foot
48. Travis Eva
49. Sean Power
50. Jack Puzin R33 GTS-t
Reserve List
1.
2.
3.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
