Well new motor is in and looking like my car may be done for this DECA! Better get off my arse and enter :)
Oh damn, I was hoping that you'd bring it up in the state it was in last DECA... and we'd all be able to share the joy of a blown motor limping off the skidpan
All your mods were external bolt ons right? Unopened head?
Guys don't forget we are after people to help run the day.
So if you coming up and bringing a mate , girlfriend ,boyfriend, mum or dad get them to help us out.
Cheers...
http://www.skylinesaustralia.com/forums/topic/429716-deca-officials-volunteers/
Yeah pretty much. Unopened motor. Took/ taking the opportunity to fix some niggling issues at the same time. So still not 100% my car will make it.
Sorry mate... on the list now!
Not sure why it didn't come through
Hi guys,
Have paid on 30/7 and sent forms via email but haven't been registered on the list.
Have just re-faxed forms also.
Can you please confirm if you have received my forms?
Cheers,
Thang
On the weekend gave my calipers a good cleanup and fixed my guard liner which kept popping out due to lack of plugs... has scrubbed under full lock since the last deca :P
I've got a week off next week, so I'm considering dropping into Shockworks and seeing what they can do for me in regards to coilovers, plus all bushes all round. Stop this horrible suspension clunk and bouncy 10+ yo Bilstein Shocks.
Are you talking about Meeting at Wallan or similar at 5:15 in the morning for the drive up to shepp?
Most of us stay up there on Friday night at the motel (see the accommodation thread)
Do the bushes at least. Rear alloy collars are amazing.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
