Sorry to hear about all the drama mate..
I just threw out an RB30 crank on the weekend because its been sitting in my shed for the last 3 years!
Series 1 & 2 cranks are the same - its just the block that differs
Don't rub it in his face that rb30s are cheap as chips here! :)
hi mate,
that's one nice Z. I just went through that kinda pain in the not distant past...
in regards to your oil filter block. if the stock rb30 threaded screw on fitting is there, you might want to measure the exact diameter on it, then check the block sleeve.
My first motor failed because I left the 30 one on, which is a beez dick too small for the sleeve, and oil does not circulate properly, and caused the same failure that you have suffered.
if you do have the rb30 one on the block, you need to get another one, or rb25 one which has the thicker sleeve.
Edited by SilverECR33
Those bits you found look alot like the woodruff key or keyway that holds fhe crank gear and balancer on.
Im putting an oil cooler on my rb30 thanks for the tip ecr33 i might have done the same...
But he found them in the head!!
  • 1 month later...
  • 5 months later...
This is the cometic exhaust gasket, what a pos.
This is the tomei exhaust gasket
Cometic
Tomei
Also on the crappy cometic gasket the rivets on the gaskets would need to be removed.
So thankfully I have a mill so port match the big boy head ports.
And for the grande finale
Shazam another one bites the dust. 2.7 miles that one lasted.
Well I'm assuming the valves are going to be bent. i got everything back to TDC with the belt off, the idler snapped. WTF man i bought a cam belt tension gauge and had everything set to 196nm. WTF
The man's trying to keep me down man i swear.
