Feels weird at first. But I promise you, once you see what it can do for you the first time, you will forever use it!
Just try it on a light weight for your first time, so you can get used to lining up your arms in parallel. It's not uncommon to pull a muscle if your arms aren't both straight. Then when you're confident with the movement, start using it on max weights and watch as your grip issues fade away.
Another technique for sweat in absence of chalk, is to use paper towels or even toilet paper from the bathroom, and line your hands with it during your grip. Will stop sweating and is much better than nothing, albeit still not as good as chalk.
Yeah I've heard about pulling a muscle using that grip, that's why I didn't try today. Will definitely give it a shot next time.
That's a brilliant idea about the paper, I'll give that a shot too thanks
No mixed
your form is probably not great.
Hips need tp be higher likely. Squatting up will mean not enough tension in arms in setup. The slack causes a jerk in motion which taxes grip.
Your back will fail first done right.
Either that or keep going till grip is stronger
I disagree...switching to mixed allowed me to strengthen my overhand grip simply by being able to lift heavier weights and concentrating on the back lifting part of the movement instead of worrying about grip slipping.
I'm fairly confident my form is decent, I'll chuck up a video when I can get one and you can critique it if you'd like.
I'd like to stay overhand as long as I can, but I'm slightly disadvantaged not being able to use chalk, also I sweat f**kin heaps haha
Edited by r31slpr
Just give mixed a go mate, you've nothing to lose...it will add another 40kg to your deadlift before you even need to worry about strengthening your grip :)
Sure it helps but, if you are letting go of sub 200kg with overhand then either you could do with better grip ( the deads will help) or you might need to raise the hip height and ensure you have slack taken out of the lift. Mixed grip can have it's own down sides.
Deads are a compound movement so grip improves with weight. You achieve balance so it's a better idea. unless you are chasing the isolation for the back more . In that case, someone suggested straps before.
This guy is starting out. If his grip is flagging at the relatively low weights then I'm guessing form is the issue.
Been pretty slack lately, I'd like to say it's beacuase I'm studying, but it's not I'm just lazy haha
May as well chuck up some starter goals for myself. When I get to them I'll change them.
I'd like to get body weight reps (around 100kg) of Row, Mp and Bench
20 pullups, more if possible
150 squat
200 dead
Anyway, todays workout
I'll start putting in warmups now (when I remember them) aswell so I can keep better track of whether I'm progressing
30/08/2013
Lunges: Lots 45kg
Row: 1x8 @40
2x5 @ 60
3x5 @ 65
Mp: 1x8 bar
1x8 @20
3x5 @30
2 reps 35 :verymad:
Edited by r31slpr
Cheers, haven't really been anywhere just lazy haha
01/09/2013
Rev was semi right with his comments about my dead form probably being wrong, except my hips were too high not low.
Don't know if it was dropping my hips a bit that helped or if it was that I was wiping the bar down with paper like birds suggested, either way no problem with grip this week.
Lunges: Lots 50kg
Dead: 1x8 @80
1x5 @110
1x3 @120
1x8 @80
Bench: 1x8 bar
1x8 @20
3x5 @45
1x8 bar
Pullups: 4 and a half haha
05/09/2013
Gave squats a crack tonight, hip is still a bit funny so weight hasn't gone up.
Squat: 1x8 bar
1x8 @20
1x8 @40
3x5 @50
Mp: 1x8 bar
1x8 @20
4x5 @30
1x5 @35
Row: 1x8 @20
1x8 @40
3x5 @65
1x5 @70 Some guy told me my back was starting to round so I'll drop the weight for next session and concentrate on form.
1x8 @40
Pullups: 1x5
1x2
10 negatives
Edited by r31slpr
Had a shit session today, squats were nice and easy for once though
08/09/2013
Squat: 1x8 bar
1x8 @20
1x5 @40
3x5 @55
Bench: 1x8 bar
1x8 @20
1x5 @40
1x5 @50 Shoulder was giving me a hard time, so I'll drop bench again for a while.
Dead: 1x8 @40
1x8 @80
1x5 @115
1x8 @90
Pullups: 1x5
looks like you are progressing along.
I found i got the most out of 5x5 when I stopped counting my warm up sets and only did working set, saving the last set for an increase in weight.
Yep progressing slowly but surely, I should really be stronger for my weight and height.
I'm only doing 3x5, I've just started tracking my warmups to help keep better track of progress.
Not really following any real weight pattern for warmups, it just varies depending how I feel on the day.
I do between 500 and 1000 meters on the rowing machine before weights as well
Water everywhere in the gym today.
Didn't do deads because too wet.
14/09/2013
Squat: 1x8 @20
1x5 @40
3x5 @60
Pullups: 1x5
1x3
5 negs
1x2
Row: 3x8 @40
Dropped the weight because some guy commented last session that my form was off.
Checked in the mirror today, my lower back looks rounded even when its not because of baggy shirt and fatness haha
16/09/2013
Squat: 1x8 bar
1x8 @40
3x5 @65
Row: 1x8 @40
3x5 @50
Form is still fine
Dead: 1x8 @80
1x5 @120 Had to wipe the bar nearly every rep, definitely need some chalk or liquid grip
1x8 @40
Pullups: 1x5 Was in a hurry to get to tafe
20/09/2013
Squat: 1x8 @30
1x5 @50
3x5 @70
Row: 1x8 @40
3x5 @60
1x5 @60
Trying to watch my form in the mirror, looks like my back is slightly rounding in the middle but it hurts if I try to arch more, it's not weight related because it feels the same without the bar.
I'm still at the conclusion that my bf% makes it look round. Just paranoid now because of that comment last week or whenever it was.
Mp: 1x8 @20
1x5 @40 Wouldn't really call this Mp, was using leg drive on a couple reps, just wanted to see if I could do it.
1x5 @30
1x4 @30 Got super dizzy on the first rep haha nearly dropped the bar.
Pushing obviously isn't my strong suit
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
