7's would be an absolute pig (no disrespect Piggaz!!) to drive.
Fine for a drag queen auto car that you can build boost on the line but useless to drive as a street or track car.
Less comp means you can throw more boost into it but at the sacrifice of off boost driveability.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952331
pretty much this.
mine is pretty responsive, even off boost.
which is a good thing, because I have to wait a looooooong time for boost.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952383
Errr? I'm asking why so low? I wouldn't want it that low. I wanted 9.3:1 in my own engine.
Edit. Oops, read out of context. Haha!!
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952455
Sensitive!!!
Continuing Lukes post, E85 is always going to be a challenge if it's your only fuel choice. Flex fuel is always a great option. 98 and taking it easy on cruises, E85 and cane it for track work.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952471
Yep, these were comp ratios that were from a time of (all that was available at the pump)low octane ULP and non intercooled motors :-(
Yeah good call and totally correct. Fuel was shite back in 1986! No premium or ultimate back then.
You need to work out what turbos you're running and what is the intended purpose of your car before you choose your comp. If you're running a massive single and focussing on drag racing or a HP dyno hero then go a bit lower comp and pump in huge boost. If you want a driveable street car or track car with good response and minimal lag out of corners then go a higher comp and smaller turbo/turbos.
Do what works for you, not what everyone else has done as we all have our own goals and uses for our cars!
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6953949
just getting some ideas input what they run wit cars , some say low or high comp - work shop says low but I would prefer some info from owners first how it drives ect.
42r 1.01 rear 3L block full race head 260inlet/270ex 10.25 lift powerglide
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6954213
I have gt42 china, 26/30, 256 9.15 lift, 9.0:1, 4" turbo back zorst.
turbo is thrust bearing, so takes a while to kick in.
still driveable due to comp ratio.
6 speed box helps too. (manual)
but, as stated, what use?
track weapon?(guessing with glide).
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6954582
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
