Yeah the back plastics on mine have plenty of cracks.
That's the reason it keeps coming back.
Tried to use silicone to seal up the cracks but it's not working.
I'll have another check this weekend and see what I can do before purchasing them.
Epoxy not silicon :thumbsup:
Okay so the timeline starts again.
So after fixing the radiator, rolling the guards, getting the coilovers installed & putting on the rims.
It was here! NATS! WOOOO FARKEN HOOO KARNTS!
I hadn't slept in days because I was so excited.
Got myself a helmet and loaded up the car with some spares just in case.
Wvyj1Qw.jpg?1
I pulled up at the nats and found myself a little spot next to Mat Geeteetee and unloaded the car.
Met all my whores from whore town who I hadn't met in person.
Who knew Tailor Made was going to have such a homo haircut haha!
Zc9hzxT.jpg?1
Got the car out on the track and had an amazing time! Didn't have any gauges so I took it fairly easily.
1-2 hot laps and then a cool down lap, this worked well for me and the car didn't give me any issues.
I walked away with a 1.26 which was an okay time for the first time ever tracking the car.
dQjCjYl.jpg?1
I participated in the track day and the airport drags.
The airport drags was the best fun I have ever had and I think I got like 10 runs or more.
My best time was a 14 seconds flat I do believe.
y4V8hAu.jpg?1
On the very last run I thought I would give it my all and spent a fair bit on the limited.
Got halfway down the track the battery light came on and the temps shot through the roof.
Popped the bonnet and coolant was everywhere.
After closer inspection I had shredded my fan belt.
Mat was kind enough to go pick me one up and help me change it on the side of the road.
Rob pulled over and had a chat while using his hazards to make sure we didn't get hit
uqJKP6x.jpg?1
This is where I would like to give a shout out to Rob for his amazing effort.
After getting home I found that we had driven off on Rob and he got back in his car and had a flat battery.
He spent a few hours on the side of the road waiting for the NRMA as we boosted off into the distance.
(Rob I still owe you that drink or 10 mate)
yinHyMb.jpg?1
Big thanks to Matt, Carmon & Rob for helping out and keeping company.
I would have been stuck there without you guys.
Ohh and here is a model shot of Josh (Tailor Made) & myself inside the car.
7Ops4as.jpg?1
After the weekend was over I cruised home with old mate Trozzle
bPRthGa.jpg?1
NATS! WOOOO FARKEN HOOO KARNTS! Indeed! :D
Twas my pleasure and in reality, my Battery was only 2 months off Death anyway, so not your fault. :thumbsup:
But I'll still Have those Beers ya flamin mongrel! I'll keep these Winkers for Ransom til you make good. :laugh:
And yeah... Mat - "34GeeTeeTee" Legend. :thumbsup:
So I cleaned my throttle body a few months ago.
Not thinking I actually cleaned off the sealant around the butterfly.
Could this be the cause of high idle?
How would people go about adding the sealant back and what would you use
I did the same thing and my car idles at 2000rpm now. Makes driving slow nice and easy as you don't have to accelerate.
The sealant is some special crap you have to buy if you really want to fix it. I'm pretty sure it's from tomei.
Source of your whistle?
could possibly be
This could be the reason that you only get it on a certain vacuum
Because it is in a certain position that causes the whistle.
Now just to find out what product I can use.
Some say gasket sealant but I don't want it to get sucked into my engine.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
