Yeah the back plastics on mine have plenty of cracks.
That's the reason it keeps coming back.
Tried to use silicone to seal up the cracks but it's not working.
I'll have another check this weekend and see what I can do before purchasing them.
Epoxy not silicon :thumbsup:
Okay so the timeline starts again.
So after fixing the radiator, rolling the guards, getting the coilovers installed & putting on the rims.
It was here! NATS! WOOOO FARKEN HOOO KARNTS!
I hadn't slept in days because I was so excited.
Got myself a helmet and loaded up the car with some spares just in case.
Wvyj1Qw.jpg?1
I pulled up at the nats and found myself a little spot next to Mat Geeteetee and unloaded the car.
Met all my whores from whore town who I hadn't met in person.
Who knew Tailor Made was going to have such a homo haircut haha!
Zc9hzxT.jpg?1
Got the car out on the track and had an amazing time! Didn't have any gauges so I took it fairly easily.
1-2 hot laps and then a cool down lap, this worked well for me and the car didn't give me any issues.
I walked away with a 1.26 which was an okay time for the first time ever tracking the car.
dQjCjYl.jpg?1
I participated in the track day and the airport drags.
The airport drags was the best fun I have ever had and I think I got like 10 runs or more.
My best time was a 14 seconds flat I do believe.
y4V8hAu.jpg?1
On the very last run I thought I would give it my all and spent a fair bit on the limited.
Got halfway down the track the battery light came on and the temps shot through the roof.
Popped the bonnet and coolant was everywhere.
After closer inspection I had shredded my fan belt.
Mat was kind enough to go pick me one up and help me change it on the side of the road.
Rob pulled over and had a chat while using his hazards to make sure we didn't get hit
uqJKP6x.jpg?1
This is where I would like to give a shout out to Rob for his amazing effort.
After getting home I found that we had driven off on Rob and he got back in his car and had a flat battery.
He spent a few hours on the side of the road waiting for the NRMA as we boosted off into the distance.
(Rob I still owe you that drink or 10 mate)
yinHyMb.jpg?1
Big thanks to Matt, Carmon & Rob for helping out and keeping company.
I would have been stuck there without you guys.
Ohh and here is a model shot of Josh (Tailor Made) & myself inside the car.
7Ops4as.jpg?1
After the weekend was over I cruised home with old mate Trozzle
bPRthGa.jpg?1
NATS! WOOOO FARKEN HOOO KARNTS! Indeed! :D
Twas my pleasure and in reality, my Battery was only 2 months off Death anyway, so not your fault. :thumbsup:
But I'll still Have those Beers ya flamin mongrel! I'll keep these Winkers for Ransom til you make good. :laugh:
And yeah... Mat - "34GeeTeeTee" Legend. :thumbsup:
So I cleaned my throttle body a few months ago.
Not thinking I actually cleaned off the sealant around the butterfly.
Could this be the cause of high idle?
How would people go about adding the sealant back and what would you use
I did the same thing and my car idles at 2000rpm now. Makes driving slow nice and easy as you don't have to accelerate.
The sealant is some special crap you have to buy if you really want to fix it. I'm pretty sure it's from tomei.
Source of your whistle?
could possibly be
This could be the reason that you only get it on a certain vacuum
Because it is in a certain position that causes the whistle.
Now just to find out what product I can use.
Some say gasket sealant but I don't want it to get sucked into my engine.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
