LONG LIVE THE RB!
So I had a few of the locals come around tonight. Shout out to "Stinky Poo, Sinister & Wilderboy"
They brought along a jump starter and we decided to do another comp test with a starter pack giving it power.
Cyl 1 = 95
Cyl 2 = 90
Cyl 3 = 80
Cyl 4 = 105
Cyl 5 = 95
Cyl 6 = 100
Sat around and pondered the idea about costs doing an engine swap or just giving up on the dream
But Stinky Poo (Don't want to f**k up the spelling to your real name) Decided he wanted to put it back together and give it one more chance.
We put everything back in and back together and the farken bitch started first go!
Didn't even miss a beat!
Right now I'm left scratching my head as to why the compression is still so low (could it be possibly the tester itself?)
and left wondering why the car just decided to start again for no reason.
Leaves me worried I'm going to get stranded somewhere I don't want to be.
Old, Cold Engine. Maybe there was a dodgy electrical connection that improved with reassembly?
"stranded somewhere I don't want to be."
Karma (CARMA) is alive and well. :P
  • 5 months later...
Yeah no more updates, the car is just being daily driven and serviced until I can sell it.
Purchased my R34 and it's build thread will be up as soon as it arrives.
Still need to do another comp test on the 33 before I sell it to make sure the buyer is aware of what his getting.
  • Like 1
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
