Seem to have a problem with fuel on the pressure side of the system draining back to tank when the car is switched off and left for a while. I am away from work for 7 days and when I come back it takes a bit to start the first time and recently it runs a bit rough for a bit after the car is started. When driving it has a small miss, but it goes away fairly quickly
I believe it is a problem with the fuel draining back to tank and just wondering if anyone has found anything similar and knows why it might be happening
I was away for nearly a month once and the car idled horribly (Sounded like it had a super lumpy cam) for about 5 minutes. But usually when I'm away for a week its not as big a problem as the issue goes away quickly and its not so bad if started daily, but I would like to fix it. I've found check valves for fuel systems but most seem to be for Carb and low pressure fuel systems. I dont really want to start forking out for braided lines and JIC fittings etc for the fuel system, would rather a barb fitting check valve etc
Just after anyone who has had a similar problem or is it just something you have to live with?
Thanks
https://www.sau.com.au/forums/topic/429788-fuel-draining-back-to-tank/
changed your fuel pump? or maybe the internal check valve has failed..
stock pumps have a check valve as do some aftermarkets. I know for a fact that bosch 040 has no check valve and I had hard-starting problems as soon as I put one in. had to pull it out and put a speedflow check valve in just above the pump and it has started first time every time since then.
Have a Nismo Pump, and have done for about the last 4 years or so. Never had the problem to start with
I did change the FPR with another stock one a while ago, just cant remember quite when. (if it was before or after the problem started)
I have another rail and FPR with new Nismo 740's going on soon
Might disconnect the return line with the car off and see if anything comes out of the FPR at some point
Do the Nismo pumps have a built in non return valve in the pump? Or is it the little part that comes with the kit? I played with it a bit and decided it wasnt a check valve so I didnt put it in. Will have to see If I can adapt a fuel pressure gauge in there. Think I can, have an old gauge from work at home just have to get some barb fittings and chuck it in somewhere
Your talking about fuel pressure dropping off to quickly when the engine is turned off? or is the FPR supposed to keep a small amount of fuel in the pressure side? I imagine the FPR drains through an orrifice when the car is turned off to drain the pressure out of the system, but having never had a fuel pressure gauge in there I'm not 100% sure on what it should do
Thanks
I think you will find your problem is something else entirely man, I've got a fuel pressure gauge on mine and the pressure begins draining off almost immediately after switching the car off. Takes less than 5 minutes or so to drain off all the pressure. I don't have issues starting no matter how long the car sits for. Regardless, surely you prime your fuel pump before starting?
Yeah it seems like fuel drains out of the injectors and then when starting theres an air lock in the injectors or something.
Might pull the fuel pump out when the car is off the road for a look. Might all come good with new injectors and the other fuel rail and FPR yet
  • 1 month later...
I'll update this thread
I pulled the rail off today and noticed on the inlet side of the fuel rail, pretty much all of the fuel had drained back, Then pulled the return line off the fuel regulator and there was fuel and a little bit of pressure. Some air and fuel came out, had to block it off.
My fuel tank doesnt really pressurise anymore so not real sure if this is normal or not. Car had been sitting in the shed for about a week before I pulled the rail off.
If this is normal I think I wont really worry about it I think. Have another rail with new injectors and fuel reg on it so something there might fix it anyway lol
Not sure if the fuel damper could be the issue, seems unlikely but dont know much about fuel dampers
Edited by 89CAL
Sounds normal to me. Unless you have a check valve in your feed line, there is nothing holding pressure there. Whereas in the return line, your pressure reg will hold some pressure.
Not sure how correct I am, but that sounds right to me. My return line usually has a little bit of fuel in there when I pull it off.
Yeah the only odd thing I thought was that the little bit of pressure I described was on the tank side of the reg. But this may just be how the fuel line is run (fuel gravity feeding back towards the front when a line is removed)
Yeah I'll just live with it I think, it's not that annoying unless I havent driven the car for a while
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
