No doubt many of you have read this blog article: "the Truth About Kilometers"
It's a good one, I have to say it very much rings true in my own experience.
You'd think that after a certain importer had a "coming to jesus" moment and before writing a great blog expose', and before reselling the services of an admittedly very useful odometer checking service - they would: "clear the decks", "make a clean sweep" etc...
And so we happen upon this lovely red evo 6 TME: http://www.carsales.com.au/dealer/details/Mitsubishi-Lancer-2000/AGC-AD-13862163/?Cr=1&sdmvc=1
WTF?
I have to say even I was convinced by the blog - making this all the more disappointing.
Edited by dodgyimports
  • Like 1
The ad currently reads 134,000km. Has it been updated?
Awww :( it looks like someone isn't playing fair - AGAIN. oh well - it's lucky i took some screenshots (click to view full size):
To their credit, thats a very quickly issued correction - respect. And at least these guy put VIN numbers on their carsales ad's - there are plenty of other dealers who post invalid VIN's or none at all - I wonder why? :)
  • Like 1
you'd think they'd make it 134 xxx km's rather than 134,000 neat. every time i see even numbers like that i think it's dodgy.
Pretty sure carsales doesn't allow you to write 'xxx' in that field, so i think rounding to the nearest thousand (assuming it is legit!) is perfectly fine.
Edited by colourclassic
i didn't mean actually writing XXX but i meant writing any combination of numbers that wasn't rounded.
Generally what they rely upon is showing a copy of the Japanese deregistration which has the kms recorded upon it. People then make the assumption that the kms showing on the deregistration were taken when the vehicle was deregistered for export.
However in reality, the kms showing on the dereg are actually the kms recorded the last time the shaken was renewed which could be several years prior to dereg.
What some nice people are doing is rewinding the kms to the point showing on the dereg and then using the deregistration as "proof" that the kms are legit. If you're lucky enough to even see that certificate, you'd go away quite satisfied.
Unless you read what I just posted, of course.
I thought it had the dates for the Shaken on the dereg . Is it not clear? Trying to remember what mine looks like....
Good point there, another thing to look out for.
Just to chime in..
The Car's KM's are definitely taken down when de-registered.
Every Customer's cert I have seen as a deregistration odo-check done ; a month before the Planned Date of Export on the Certificate.
Just to chime in..
funny how the carsales ad is changed to 134k kms now.....
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
