Noooooo :(
I may still be able to make it yet not 100% sure, just depends on how the next couple of days pan out.
If I can, Ill probably be coming up with my partner in her Mazda3, as the car is still at CRD. Its sooooooo close, I can almost taste it.
Its been so long since I got to drive it in any sort of anger, its driving me crazy!!!!
Hang on... the cruise organiser has bailed....? Who will be the new organiser person?
not bailed lightly.
just follow the instructions, someone will take the lead.
im new to skylines australia and would love to meet up with members and go for a drive and get others opinions on my r33 :) where can i find info on the cruise
Hey Jake,
All the details are on the first post of this thread. Certainly come along! Will be a great day out.
  • Like 1
Yes Jake - you're most welcome to meet at
a) Casula HomeMaker/KFC at 9am > leave at 9.30
b) St Paul's Primary School Tongarra Rd at 11am > leave at 11.30
...then on to the Pass
Hey this will be my first also, SAU cruise cherry popping all the way haha
Will be a great day and can't wait to check out the 33
awesome stuff cant wait to see urs either theres some pics i put in the gallery
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
