Sunday no rain.... so it will be ok to spray etch primer after the predicted fog clears.
Cant spray when its humid, i dont have a booth.
I might spray all the primer on sunday/moday.
Edited by D.I.Y. Mik
Thanks guys :laugh:
So it looks like after tomorrow its going to be raining for a while
Might just peel off the tape for now and keep working on the little bits untill the weather drys up again.
Will get some good soda media this week, that will help with the doorhandles and the grooves in the brakelight surrounds etc.
Primer filler:
post-89755-0-39715000-1393904785_thumb.jpg post-89755-0-07164600-1393904804_thumb.jpg
Guide coat tonight and peel the tape.
Then the long process of block sanding: filling, sanding, more primer, sanding, sanding finer, and finer again.
It will keep me busy for a while.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
