Hmmm... I wonder if ECUtalk can connect with a Nistune? I'm guessing yes but I'm unsure.
Try unplugging the ECU and reconnect incase there is a dodgy connection?
Unplug and plug in everything. :D
yeah interesting...seems like the basic checks have been done OK.
it is a standard ECU right? plugging in a powerfc and hand controller might tell you more.
The CAS can fail physically, as can the ignitor so it might be worth swapping both with known working ones. I am near Red HIll today but the stagea runs an r34 cas and no ignitor so I don't think I can help.
It's running a Nistune Chip Duncan.
The strangest thing is it idled and worked this morning for the few seconds until I went to take off.
That's when everything cut out and it just wouldn't start.
Has anyone got an R33 ignitor that I could try unbolting and using?
It's only 4 bolts on the top of the cam cover to remove it :D
I might try the clutch starting idea but I will need to get some mates over to help push it up the hill.
Might try that if the ignitor doesn't work
^^ agreed you have spark but is it a STRONG spark. I assume one of you have a multimeter. Do you have correct volts on ignitor cas afm. Are your grounds good, have you possibly knocked any. Is your solenoid for vct switching correctly (cant recall if your running.it with your nistuned r32 ecu)
obviously start small and obvious but if its just coincidence and there is an actual fault. A multimeter can tell you a lot ecu talk even better if possible.
Didn't change the battery Sin because it had plenty of power to crank the engine about 12 times.
Not sure if that's a mistake and I should have done it anyways.
I haven't got a multimeter so can't test voltages.
I wouldn't know what voltages to expect from each part either.
Does anyone know if ECU talk works with Nistune?
btw when you say you have to push it uphill to clutch start it, is that because your house is right at the bottom of a hill? because you can clutch start in reverse too. If you are careful (clutch and brake as soon as it fires) you can even do it in your driveway, it only takes a couple of klm/h to start a car.
ecutalk should show most of your ecu values and voltages on a PC which can help with spotting a dodgy sensor like an AFM or TPS (by voltage) or even CAS (by seeing fluctuating voltages)
Yeah I have a really steep small driveway that's at the bottom of a hill.
So once it's down the driveway then there is no way I would get it back up there.
Also it would mean leaving the car at the bottom of the hill and pretty far from sight/sound
I would love to roll start it Duncan but it would probably be last resort unless I had some rope to tow it haha
Rob can I come pick it up tomorrow arvo from you?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
