It was without but we did the same test a few weeks back and got the 150-160
I'll give everyone a break down of how I did the test and I don't think throttle matters in this situation.
-Unplugged injector plug.
-Removed all spark plugs/coils.
-Got the compression tested and wound it into the cylinder.
-Turned the key over until it reached peak PSI and then stopped.
-Recorded said PSI and moved onto the next cylinder.
This sounds good. ^^^
Batty was definately down by a couple of Volts, but turn the engine fine, Headlights worked etc...
How was the car last driven?
Easy duties or Fully Thrashin' it?
I think we have to admit it couldn't throw results that bad.
To go from something like 160 to 25 is a massive drop.
Then for the cylinder tested after that to be 90 just wouldn't make sense.
Also we tried to jump start it and it wouldn't start so the battery is not the problem haha.
dont stress to hard till you do it properly. charge that battery to 12.6v make sure you.threads are clean for each cylinder and that the compression tester is seated and tight on each plug. make sure the cylinders are not completely dry using a few drops of oil or injectors still plugged in.
have to eliminate variables to get solid results.
same with jump starting, rating of leads, clean connections on both problem and donor car, donor car raising the revs to 2kish when trying to start, also problem cars voltage cant be too low either as it still wont kick. (not everythings black and white)
If your engine is cold, then you are going to get really low compression test results. I tested my car the other week without warming it up to operating temperature and got really low CT results, ~120 psi. It had me worried, but it should be around ~160 when it is warm and the tolerances have tightened up.
Edit: Didn't see the 25. thats a bit too low
Edited by chus13
Head gasket?
check for oil in water and water in oil
You could do that in a few hours if theres no head warping, trojan prob have a gasket on the shelf
re test for sure
Edited by D.I.Y. Mik
those numbers are too low double check that the tester was sealing correctly or that there isnt something wrong with the tester (try it on a known good engine), also compression tests are done with the throttle completely open (foot to the floor).
stick the battery on a charger or do the test with jumper leads connected to another car so it has some decent volts while testing.
Thanks again guys
Okay so I'll try a re test tonight and do it with open throttle. Also stinky if you are free this afternoon that would be great if you could swing by with some r33 parts and jumper leads?
If not I could borrow a car possibly and come borrow parts off people :)
Already got a tool box off Bryce and comp tester off Verms haha
Timing belt has not been changed since I have owned it. And I have had it for about 45,000km
Not sure when it was previously changed
What would happen if that was to break?
Does it still do huge damage at idle when something like that happens?
Timing belt breaks > nothing governing camshaft rotation > pistons mash valves.
If your timing belt broke you'd probably have heard horrible sounds as the pistons slammed into valves, rather than it just conking out like you indicated.
I'm still thinking something electrical...if the timing belt snapped and it mashed valves, given one cylinder is significantly worse than the others I'd like to think there should be at least 1 cylinder that reads almost normal (valves closed and intact)
Dude im sorry to hear that. I thought the same thing when we tested my engine, running ZERO PSI on 2 Cyl and about 10-20 on the other four. It's a shame i didn't take photos of what was left of my pistons when the engine was pulled apart.
Honestly id just pull the head off and check it. Hopefully its a gasket but it sounds like something more important. Just get a $1500 engine and swap your parts over. Maybe even find a whole 33 for like 2-3k so you have a full parts car.
I'm hesitant to suggest gasket as it'd be a bit unlikely to fail across every cylinder wouldn't it? I'd have thought once it blew the weak spot out, that's it and only the cylinders that needed that bit of the gasket to seal would show low compression....also if it failed on this scale, you'd be guaranteed water in the oil system and visa versa.
I should point out everything I suggest is just speculation. I've never dealt with engine failure or anything close to this scale of fail, so I'm just relying on my firm grasp of internal combustion engines and what effects what, particularly with RBs :)If I wasn't such an academic failure through school (thanks to giving almost literally NO f**ks for it), I'd be a pretty bloody decent mechanical engineer lol....just the way my brain is wired....unfortunately I'm just lazy and have next to no attention span for things that don't interest me :(
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
