Can anyone shed some light on what the next steps should be?
I was thinking
-hook up jumper leads and do another test.
-pull off the timing cover and check the belt
Then if stinky comes around this week.
-Try a new VCT unit just in case if he has one.
Anything else?
yes that is what I would do.
Redo the compression test while hooked to a running engine by jumper leads
When stinkypoo drops by, swap the ignitor, CAS, AFM and ECU (one by one) and see if it makes a difference.
If still crappy results and no luck, take the timing cover off.
Timing cover is like...3 bolts isn't it? The upper half of it at least. It'd take no time to pull off and look at the belt, should be blindingly obvious if that's the problem lol.
I'd check the things that take the least time to do first.
true. I'm not sure how much work it is on a stock 25...on a 26 it needs CAS off, water line disconnected (possible re-bleed) and then about 3 bolts. not a big deal. You should either carefully mark the CAS position before removing it, or redo the base timing after.
Yeah so I can't swap out an ECU which is a bit of a pain because its a nistune R32 ECU.
Using the Window switch (Not the jaycar one) its the proper window switch.
Checked that last night and it seems fine.
Rob pulled out the ecu and re connected just to be sure.
Yeah I will re run the test tonight hopefully ( is it okay to use a jump start pack thing?)
If it's easy to pull the cover off then I will check that as well.
Hopefully stinky has time to stand in the dark and cold with me and try a CAS or maybe even see something I am not noticing.
Daniel - pm your addy and I'll drop around a fully charged Battery, a Jump Pack and Jumper leads after work.
Edit: Oh and a battery charger :)
If tonight was like last night maybe drop off a few jumpers as well :P
LONG LIVE THE RB!
So I had a few of the locals come around tonight. Shout out to "Stinky Poo, Sinister & Wilderboy"
They brought along a jump starter and we decided to do another comp test with a starter pack giving it power.
Cyl 1 = 95
Cyl 2 = 90
Cyl 3 = 80
Cyl 4 = 105
Cyl 5 = 95
Cyl 6 = 100
Sat around and pondered the idea about costs doing an engine swap or just giving up on the dream
But Stinky Poo (Don't want to f**k up the spelling to your real name) Decided he wanted to put it back together and give it one more chance.
We put everything back in and back together and the farken bitch started first go!
Didn't even miss a beat!
Right now I'm left scratching my head as to why the compression is still so low (could it be possibly the tester itself?)
and left wondering why the car just decided to start again for no reason.
Leaves me worried I'm going to get stranded somewhere I don't want to be.
My next step is maybe take it to a workshop for them to triple check everything.
  • Like 1
Thanks to everyone for all the help over the past few days!!
I really really really can't thank you all enough!
Glad this didn't make it to page 10
Long live the RB!
And yes a warm/hot test will be a good comparison because it can be lower when cold right?
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
