  • Replies 87
My mechanic and i have spoke about turbo choice, we are going ahead with the garret gtx3076r.
Thanks for your help hypergear and thanks to any one from the skyline australia forum for helping out also.
Hmmmm just don't know ! Nothing wrong with that choice, i run it! but a hyper gear would be awsome combo on your car, what rear housing you going to run? you going internal or external gate?
Well I believe there is a strong Bias on his engine builder as many older timers did grew up with the company, even thou I do not agree that it is a better choice for factory manifold and internal gate, but I respect their decisions.
As developments continues, I will make sure the SS internally gated series are always a better bolton option for the Nissan Rb25det engines.
I run the same turbo, the GTX is only a good choice for someone planning on running 25+ psi, otherwise the GT or a Hypergear is a better option imo.
It is a fairly laggy 400kw on e85 turbo choice. What do you want out of your setup?
Just saw he wants to run x frame mine is gt 3076r not to laggy at all with a .63 external and manual lol makes good power, but will expect it to nose over soon on the next time hopefully get 350+ out of it b4 it does , but there are much better choices out there now, more response, better flow, I know I will be changing to some thing else one day soon, but just like to see where I can push this combo too first .
2000 rs you have spent massive $$$ on that stag now and deserve to make good power so be very very careful on turbo choice and who you take advice from . There are ppl on here who are specifically in tune with stagea's and rb engines and turbo choice too suit . You've also got too look at what power delivery you want , do you want a dyno queen lag monster or something that will actually get the stag up and moving street style, do you want a linier v8 style power delivery or do you want a head snap . Be careful on what path you choose
And mechanic so strongly in favour of one turbo over another (when the one he's against is arguably the best choice) isn't a mechanic worth taking your car to.
Seriously, for what you want I doubt you'll find a better turbo than a HG. There are lots of results out there which demonstrate how perfect HGs are for RBs. If your mechanic isn't confident using one, then he has a problem, not the turbo.
I vote find a new mechanic
4bidn1 has a a 3076 56t ,63 same setup/gate on stockyband he had auto aswell
i have hypergear g3with old bigger 58t comp wheel/bigger turbine/bigger .82 exhaust housing
now lets guess which one has way more power under 3800rpm
the 3076 woudnt even make 1psi on a stock converter..
of course you workshop woudnt know this...
remember you have to move a big heavy car. Good ole adelaide
workshops..lol
.82
internal wastegate.
Dont want the cops to have a heart attack when they pop the bonnet.........
Edited by 2000 RS
I am running forged pistons, plan on getting mv auto to strengthen my trans and put a stall converter in..........
The workshop im sending my car too works mostly with rb engines, they have drift cars also.
They have worked with alot of HG turbos, they say they cant get no where near the figures HG have posted on the net Plus the front housing on HG turbos are to big for my application as i am not running a top mounted turbo.
What figures do they get on their Garrett range?
Just on that, are you buying the turbo from them?
With the gt3076 they make around 330rwk on a manual.
And yes they are getting the turbo in for me, i payed a deposit today. the gtx3076r is $2450
The gt3076 is $2050
You pay for what you get these days i guess.
well not really..you got assf**ked by bill with your first turbo, assf**ked by your engine builder
theres plenty of info here to tell you why the gtx3076 woudn't be a good thing for what you want
but you seem to like to get spoon fed,your the type of customer workshops dream about..lol
money doesn't buy brains sadly
Edited by jet_r31
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
