I am parting out a r32 gtst the car is NOT complied so cant be registered so I am parting it out... engine has low comp in no.1 and blows lots of smoke... car is silver and I am not selling it complete unless you want to pay $5000
bonnet - $150
type m front bar - $170
type m sideskirts - $170
rear pods - $100
seats - $150
cluster (65,000kms) - $80
speedo cable - $80
cusco strut brace - $100
front coilovers (I think hsd) - $350
rear coilovers (yet to check brand but dont match the fronts) - tbc
non abs bmc - $80
centre console with mint lid - $50
radiator - $100
fmic with alloy piping (near new) - $200
3'' catback exhaust - $200
5 bolt lsd - $150
drive shafts - $150
door cards - $80 for pair
engine crossmember - $120
steering rack - $80
gearbox - $450
bare engine with low comp in no. 1 - $150
front reo bar - $150
mint dash with vents - $250
projector headlights - $200
full manual conversion - $900
5 stud conversion - $450
front guards - $80 each
tail lights - $100
rear reo bar - $50
mirrors - $30 each
everything is for sale besides the seatbelts pm or 0420 767 957 for pics or more info
located springwood 4127
https://www.sau.com.au/forums/topic/430563-wrecking-1992-r32-gtst-complete-car/
Cheers Corin, it was the coil packs that were playing up, though I'm still interested in the afm for one of the other 32's. I've got rego and insurance next week, but if you still have it in a fortnight I'll more than likely grab it off you, but if someone else wants it, by all means sell it to them.
By the way, that exhaust I picked up from you was much less noisy than I expected, which is good :) exactly what I wanted, no drone either.
Mike.
No worries Mike I will still have an afm... good to hear that your happy with the exhaust :)
Mayby4 the front bar is sold, I still have the rest...
Edited by SIFTY32
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
