Hi all,
I am looking to get opinions on whether the Meguires lens restoration kit is any good or not? I have faded headlights, and i think it is all external and this kit seems like a good place to start.
Is this any good, or are there other products you would recommend?
Finally, is there anything else I need, i saw something about UV protector or some such?
Cheers
https://www.sau.com.au/forums/topic/431036-headlight-restore-kit/
Hi Lemonnuff31, I had this same issue. My headlights were getting opaque with a slight yellow tinge. I didn't purchase a kit and opted for three of the lightest grit sandpapers to use in conjunction with plastX and a polish buff drill bit....think i saved 20 bucks or so doing it this way. It did the job nicely and i was happy with the result. I think with the plastics used on headlights these days the coloration and smokiness is bound to happen with exposure to UV and the elements. I don't think its a one off thing to restore headlights but a little job that needs doing maybe once every few years to keep them looking immaculate and clear. There is science behind different plastics and how they react with varying chemicals and when i cleaned mine i didn't get to finicky and just went with the most tried and tested approach. When i do mine again ill be using the Meguires Kit you mentioned.... It comes with the plasiX included in the kit.
bought the decent kit from autobarn... looked immac for about 3 months then the UV sealant started to look patchy like it was flaking off and the yellow started to return... think next time I do it im just going to use a polishing pad drill bit and buff the f**k out of them as a plastic s13 grill that was yellow turned out amazing with the buff pad
I have tried one of the kits (RainX kit). And if I had to them again, I would just be buying several fine grades of sandpaper and looking for the sealant on it's own.
I found the polish that came with the kit was next to useless. After using the sanding pads and perservering with the supplied polish, I ended up using my rotary buffer with a foam pad and a fine cut paint cleaner which did an awesome job of cleaning up the headlights after sanding. Made them look brand new. I then just applied the sealant the came with the kit. PlastX with a rotary buffer would probably work well too.
That was about 6 months ago, I live in North Queensland and my car is parked in the sun all day, and it still looks great!
Meguires do make the UV sealant on its own. Only problem is they do not sell it in Aus....YET!
Invision do not make the sealant by itself. I did ring them and they said they plan to do a bigger bottle in the future amd sell the products individualy in the future aswell.
Will the invision pack you need to be sparing with the sealant. V35 headlights are exactly small.
Lol the Meg's stuff is useless shit! Last about 3 months, and becomes worse than before a lot quicker. Their sealant is .... Okay(loosely used) but doesn't last very long.
I used the glassylite kit off eBay( $35) and it lasts about 10months to a year. Pics?
Check out this shit
Don't have any before pics as I wasn't expecting THAT good of results. But it worked wonders.
  • Like 1
  • 3 weeks later...
guys the resto kits all work great, toothpaste will work great....we need to find a good sealant which stops the degrading process and group buy.
must admit the kit i got from sprints, i think maguires, has still held up very well for months.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
