Mugabetown - Whoretownin' At It's Worst.
Sif be at drinks when you could do 12 hour days all weekend
12 hour days suck balls - I feel for you, I am lucky if I get one day off per week sometimes 2 per f/n let alone 28 days on...
Where abouts do you work?
28 on is about the worst roster ive heard. 14/6 is the most id do f**k anything else.
12 hour days are absolute standard in construction though so meh harden up Pete :-P
Thank f**k this week is over though, whatever could go wrong did go wrong this week. So shit.
Bring on long weekend and North Straddy awww yeah
I'm only doing 21 days this swing and back to 14 days next swing, don't feel bad for me, heck 1 day off a week is worse in my book, you just have the luxury of that day being a weekend, and things like long weekends, and being able to go to things/events after work etc.
Moaning is just the only thing that keeps me going through the days :yucky:
MCJV does a 28 day roster for some of its staff though... I can conclusively say, screw that!
A few more photos
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1380884143.715177.jpg
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1380884158.767778.jpg
This makes me yet and difficult to go to sleep.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
