Mugabetown - Whoretownin' At It's Worst.
with my boost controller switched off, it will run the minimum the wastegate spring/preload allows, so long as there is no damage to the wastegate lines.
that would be consistent with wastegate functioning correctly :) What pressure wastegate spring limits your boost?
I have often wondered about Wastegate actuation, as over time vacuum drops in an engine and the wastegate seals wear. So unless you constantly adjust it the boost control will lessen over time - good reason not to buy used wastegates.
On a far less serious note, and in response to 2.1 bar boost. In a modified GTIR years ago a friend used to boast that his engine could handle anything failing, so another friend told him to disable all boost control (wastegate locked) and remove the knock sensor for a 10 second full throttle blast. The thing went like a rocket - didn't blow up then, but one week later he called for a tow as he had just played catch the conrod. Motor pulled down and bearings were mushroomed and block had an awesome porthole. :)
lol......epic fail to that Gtir.
Having said that 2.1bar is no laughing matter
Yep, he was initially really happy about proving the doubters wrong until the engine died.
2.1 is high. I remember years ago hearing that Rigoli was ordering 5 bar map sensors, as the 3 bar were out of range on the racecar.
yeah those Rigoli boyz were truly nutz!
I remember their 4WD Hyundai Accent which ran 10secs or less
Waz crazy what they did by transplanting an Evo drivetrain in that chassis........but it worked!
That was the exact car - good memory :) the rumour was 43psi. I think it had a T60 or T70 Turbonetics custom turbo from memory.
See this thread for fond memories - 9.4sec 1/4. http://www.skylinesaustralia.com/forums/topic/26511-rigoli-accent-in-the-9s/
Yep. Good times mate.......good memories.
I also happened to own an accent att when they did that lol
Turbonetics rings the bell as well.
Pretty sure I have a FastFour Mag somewhere about it
1.7 bar spring, lots of preload, did a few more tests consistent 2.08 - 2.1 bar, so needs to be backed off a tad.
there is a black evo 5 thats running 501kw @ 43psi, its currently on the market for 30k
and shipping? Happ are in brisbane. Ramps already here
morning Tony
Edited by MagicMikeZ32
so wastegate spring 1.7, no boost control gives 2bar? Boost creep?
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
