Mugabetown - Whoretownin' At It's Worst.
Morning mate
Sounds like a good plan
Igniter is in the coils, does not look like loom or coils TBH they operate under load and at speed, not plugs either.
Background on the car:
400rwhp r34 gtt
never had an issue with missfire ever
109000K's
only missing at revs while free revving
no issues under load or at max boost (23psi)
Igniter should be a separate unit consisting of transistors/diodes. they are on the back of the rocker cover on rb26s - not sure where located on r34gtt. They are also referred to as a Power Transistor Unit
I believe that in s2 Rb25's and neos, the ignitor is inside the coilpack. Unlike the s1 Rb25. I'm not familiar with 26 setups though
RB26's have their igniter module at the back on top of the plug covers.
rb25s - Answered
MagicMikeZ32 would know all about them failing lol
Mine were 20+ years old, no issues. Don't even need engine out to change them.
Having said that, I am using yellow jackets at the mo, for no aparant reason other than 'modify'
Not the coils the PTU in Z32s. I had to replace mine. http://forums.nicoclub.com/tip-for-ptu-problems-t276337.html
http://tech.aus300zx.com/ignition/ignition.htm
So thats the difference between S1 and S2 packs.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
