Mugabetown - Whoretownin' At It's Worst.
Well goodnight bishes...
Taking my nose piercing out, it's so sore and annoying. Yay a normal nose again haha :/
extra breathing hole lol
Nite Kath.
Congrats on the new acquisition too :)
well ok then. I won't participate to LP.
You would be fine around lakeside ants. Just go at a pace you're comfortable with. I did a few lakeside happylaps and had no dramas and last time I checked I had a white 32 gtr
Its Ok. I have survived multiple happy laps at lakeside! White GTR and all.
You have to be a special type of dumb to have an incident at happy laps. Sprint days are another matter however.
Ive never been to Lakeside. Might be worth attending
Do et. I was taunted by lakeside the first couple of times. But I actually prefer it now. Brakes tend to cook less.
thanks mate. I think that can be applied to every track. I'm no superstar racing driver and although I like the idea of flying on a track, I know very I'm totally incompetent, and need to learn how to drive it.
I'm so pissed at myself for missing out at QR. It would of been a great opportunity for me to drive there with you guys.
Can't wait for next track day. I have to get that clutch cooling fan replaced first.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
