Mugabetown - Whoretownin' At It's Worst.
I didn't have hangover food because no hangover... But I did rage at pancake manor and get discount on foods! Took an hour to get our food this morning holy shhhiiiitttt!!!
Then came home and washed two cars and I have to work tonight... Waaaaaaaaaaaaa for working on weekends!!!
Sounds like Pancake Parlour in Civic... Except there food also tastes terrible.
And I just remembered... I have bacon, eggs, and hashbrowns ready to be cooked... MMMMmmmm... That might be a reason to finish building the BBQ...
At work living the dream.
Thought I'd take the Skyline to work for a change, went to start it and battery was dead.
Even the skyline doesnt want me to drive it
not driving it for over a month will do that Scottie
It got a 15min drive about two weeks ago. thats should be enough lol
yeah, I've gone through too many batteries like that. So whenever I know in not going to use the car for a long period of time, I just yank out the battery and recharge it if necessary when I need to use the car again
You need to put the ammeter in line and see what sort of current is being drawn, pull a few fuses until you find the circuit that drops the drain.
yeah. Il borrow my bros ammeter to solve that issue.
Ok old diff is out, new diff is in, Hicas is off (now I need a lockout kit), still need rear 5 stud hub assembly :)
I'll be selling my old lock bar this weekend...you and Mel can fight for it.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
