Mugabetown - Whoretownin' At It's Worst.
Spent 2 days on the o2 sensors.
$100 on specialty tools and a few skinned knuckles later, I have 1 o2 out FML.
Avoided engine out tho :P
Not engine out??? But I don't understand... :blink::P
Not great no, but it wasn't exactly economy driving either. I imagine quite a bit of fuel would be flowing when its developing 400hp.
Should probably put O2 sensors in to help that. Presumably there's only 1...?
wut? usually there are two 02 sensors on RB26
Strangely enough I only have one now that I could spot under my car
Found the second one on the top of my dumps, can't figure out what is going on with the plugs though. Got a pair of 3 wire ones, one flat plug one square.
edit: images
Couldn't for the life of me find another 3 plug one like the top one. Dunno where i'd be supposed to plug the second sensor into then...
Nissan made it idiot proof, the plug on the front o2 is flat and the plug on the rear o2 sensor is square
Defeated my o2s finally. Another custom tool for the collection.
now im guna need a new 22mm spanner...
I live my life a 1/4 of a 1/4 of a turn at a time
Edited by MagicMikeZ32
  • Like 1
Turbo xxxx ECU, injectors, fuel pump, FMIC, Hi flow cat (perhaps)
R34 Turbo Brodi $200
Turbo Highflow, Hypergear, $860
Braided Turbo Oil Line, Hypergear, $88
High Preasure Actuator, Hypergear, $120
ECU, Haltech Platinum Pro Plugin, $1,975
Flex Fuel Sensor, Haltech, $250
Injectors, ID1000's, $720
Fuel Pump, Nismo Intank, $385
Fuel Pressure Regulator, Nismo, $132
Highflow Cat, Venom, $250
Tuning, ???, $1,000
Total $5,980
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
