Mugabetown - Whoretownin' At It's Worst.
Hi mate *ants wants to see the unicorn chopping dirty commos and evos
Sir President *tips hat
Duchess Pinky *ants bows
*courtsey*
howdy? Lol. Duchess... :P:yucky:
Yeah Tony, you read what he said, all class here... :thumbsup:
With her new job she may not make it all that often, as Mondays and Tuesdays are her days off but Sundays might work, are they ever on Sundays anymore?
still very very early on Sundays mate
Getting used to my new work PC.. I get into the start menu then get fkn lost as to how to get back to the desktop, worked it out eventually haha... Runs well tho :)
Windows 8? You can use this to make it work like Windows 7 (or other classic taskbar styles).
http://www.classicshell.net/
A bit of playing around and I am used to it now... One of the PCs was upgraded from XP, so glad that old one wasn't mine!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
