Mugabetown - Whoretownin' At It's Worst.
howdy peeeps
how is everyone? i have been off the radar for a long time now for various reasons. hope to get back to normal soon. have a tumor in my skull that needs to be drilled out.
ps. anyone know much about the 300ZX Tommy Karia Edition?
My friend had that done when we were in High School. At least they found it, all the best for the procedure, I am sure you will be back at it in no time :)
howdy peeeps
Not good to hear benno, best of luck.
RE the 300ZX, I know that it'd involve just as much engine out.
well it is a lot better then drilling for CSG. I cannot believe how retarded our government is to allow it to happen on our soil. One only has to look to the devastation caused by fracking from the USA. Checkout a doco called Gasland by Josh Fox if you haven't already seen it.
The lure of the revenue is too great.
don't mining companies have an obligation/ responsibility sanctioned by the Australian Government to return the area drilled or mined to an environmentally safe and natural state or this not reinforced as well as it should?
My personal view? I don't beleive there is a strong enough knowledge of the risks to create appropriate conditions to manage those risks.
I would love to hear/ learn more about this mate.
Maybe over a beer (or two) one day :)
Teins have arrived
Inb4 queries about Sydneykid bilstien package - is on hold due to other financial commitments and current coilovers are well and truly f**ked
You didn't consider doing bushes and ball joints first?
  • Like 1
yeah, slowly acquiring the parts Grego (already have the rear subframe bushes from whiteline)
Once I post a pic of my current strut/ coilovers you will understand
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
