Mugabetown - Whoretownin' At It's Worst.
f*cking alarm or something on my neighbours shed has been going off all night. Sounds like a truck reversing. No sleep for me :( :( :(
This sucks... f**king neighbours... Things like this make me want to be a hermit... Somewhere with pretty mountain views and easy access to some form of beach... Not asking much :P
I have an air on unit bolted to the wall sitting 20cm from my head... Every day this swing. So it could be worse!
This would still annoy me, tho not as much as the alarm... I don't like the sound of a ceiling fan and they don't make much noise!
AND HAPPY CAKE DAY!!! :cheers::merli: <--- I maintain on peoples birthdays that's a party hat not a wizard
Go burn their shed down?
Hehehehehehe! Made me think of this...
Hey Tony, welcome back!
Now when are you guna make that skyline in my backyard dissapear?
careful what you wish for Mike
The Skyline may not be the only thing that disappears from your backyard :ninja:
made me think of this...
Thinking of kids Mel?
Right after he makes your wallet disappear
I'd load the old rusty subframe into the boot too, but I can't lift it :(
Just zip tie and duct tape it to the side of the car
  • Like 2
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
