Mugabetown - Whoretownin' At It's Worst.
2 hours ago, Keegs said:
Aren't you a savy social media real estate rental wizard?
Are business owners really ever “on the tools” ?
My staff do a great job, at least that’s how it looks, while seated at my rich smelling mahogany desk.
  • Like 1
5 hours ago, Nismo_Boy said:
I was a thing.
Scene seems to be coming back...saw a group doing M1 runs the other day and some 18 year olds drifting springbrook.
Was funny sitting up the top of the hill in my GTR, a mates Ferrari and a c63....a little different to the old days ?
What are you driving now?
I drive the joy of knowing that the MQG business division owns me for 6 life times as they fuel my unhealthy obsession for buying out competitors and industry domination.
I still have the Lotus/Brabham and supercharged MG with various other pre 1950's garden gnomes (cars) in states of incompleteness and disrepair. But they're only old people fun cars.
COVID-19 hurt and even tanked my smaller competitors, so I want to do one more business buy out and leverage the advantage now before buying a modern super happy fun toy to par take in the current resurgence of highways and hills. It's been a while between boost skids though ?
On 29/06/2020 at 7:10 AM, Nismo_Boy said:
I'm too old to know what this @ # social network stuff is
Using the "@" symbol and typing a user name, then selecting that user name, will send them a notification saying someone has mentioned them.
They can then click that notification, and it should bring them straight to the post.
I do like a nice desk.
Pics?
Good luck!
Sounds like you're on top of things.
What do you have your eye on for the next purchase?
(Car wise)
  • 5 months later...
  • 2 months later...
  • 9 months later...
  • 5 weeks later...
On 20/01/2022 at 3:17 PM, RedEmblem said:
Back for my annual SAU visit. Does anyone remember the Saturday night cruises to Broadwater carpark on the Gold Coast back about 2006-2008? Those were insane.
Yep, sure do and even before that (back in the mid to late 90’s) with dropped subies, pimped out civics, boosted Starlets, fully decked GTI’R’s, Mitsus 3000gt, slick Supra’s and off course the king of street Godzilla’s
Now youre showing your age... :P
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
