That Kando housing is poo based on the many results of those that tried to use them...plus a quick look at the wastegate gases path
In what way? Needed a little wastegate porting but after that it performs excellently, well at least the T25 version does an I expect it would be virtually identical!?
Power and boost from the T25 version of the exact same turbo on an SR if you didn't see it in the Kando thread
  • Replies 50
Posted Images
Have a good look at the Kando T3 housings. Theya re nothign alike the T25 housings. They are the sme as the woeful internal gate Trust housings from that era :(
Back in 2003 when I threw my TD06 on the RB20 every result was with the internal gate version of that turbo, inc on RB25s. If it wasnt for my mate telling me to trust him I would never have tried it...as the results of the internal gate vs external gate have always been chalk and cheese
when do you hit full boost?
flip your FMIC, run it near the rad for shorter piping and make up new piping like the 'plazmaman' (or what ever its called lol )piping kit its just a 180 deg mandrel bend cut off to suit and a 45deg or so - 400/500 rpms response
get adjustable cam gears advance intake and retard exhaust -400-500 rpms response
or get a hyper gear ss1
or do a rb20de+t
Hi, my r32 (rb20) has a high flowed r33 turbo, front mount and a 3.5 inch cat back the actuator in the high flow is at 14psi.
I want a turbo that fully boosts by 2500 - 3000 ish and pulls harder than the high flow if I got it nistuned and bought a 3 inch full exhaust plus smaller turbo would that do it? Help me please or should I sell it and buy something else?
Hey guys sorry if this is off topic but i recently did a conpression test in my rb25 s1 results were as follows.
Cyl 1 - 168
Cyl 2 - 155
Cyl 3 - 168
Cyl 4 - 165
Cyl 5 - 162
Cyl 6 - 153
Is.this considered decent?
of course that's off topic! If car runs fine don't worry about engine. results seem fine. Keep on thrashing.
At the end of the day an RB20 is what it is , short stroke smallish bore 2L six based on the dimensions of the old L20A . It's never going to be a stump puller that revs like a turbine , Nissans answer was a larger bore with a longer stroke topped by a head with larger ports and valves . 2.5 litres is simply far better use of the RB blocks real-estate than 2 litres .
In real terms the only simple answer in an R32 with a RB20 is to make the car as light as possible and make the gearing suit the engines power curve . Revs aren't a problem if the gearing is suitable because you stay in the usable rev range .
Roy what would happen if you used Evo RS gearing ie a 4.875 diff and a close ratio gear set ? Actually you mentioned R31's and it would be interesting to find out what gearing the Grp A R31s used especially as some of that stuff was made here in Aus . Some of it may have been a carry over from the DR30 era as well and they may have used Rally style direct 5th five speeds .
A .
I think to sum up this thread for the OP would be to leave the car as is and throw injectors, tune and a boost controller and make the most of that. Any more will take more dicking around and $
Otherwise, prob easier for the goal area would be to sell ur R32 and get an RB25DET car (converted R32 or R33 & R34) that has been modified and tuned for the desired result you want.
and building is serious $ when a decent modded R33 that will put a big smile on his face is under $10k these days...
that's also prob less than it would cost him to sell it and upgrade VS boost, inject and tune the current one (+ clutch, + problems etc etc)
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
