Hey all,
Just need help pulling the trigger.
Im upgrading my fuel pump and injectors to run e85.
Ive read through the E85 thread but just need some advice pulling the trigger.
Im aiming for around 400kws in my 33 GTR.
Im going to use the intank walbro E85 pump, should be big enough?
The injectors im deciding between the
BOSCH EV14 1000cc + 11mm Extensions + Plugs
or the
BOSCH 2200cc Injectors + 11mm Extensions + Plugs
Will 1000cc be big enough? ive been told buy the sales team of the place im getting them for they should be?
Or for an extra $200 go the 2200cc injectors. But reading have said they arent as easy to tune or something?
Any advice or real world knowlage of these two in your own cars would be great
thanks
Adam
https://www.sau.com.au/forums/topic/431439-e85-injector-question/
You need at least 740cc injectors to support that sort of power on 98. Given that e85 needs more than 50% extra injector capacity to be safe, then 1000cc injectors is actually a bit on the slim side. I'd be looking at something bigger, but not as big as the 2200s. There's ID1300 and so on available, yes?
Ok thats what i was thinking, just getting myself confused...
Does that go for the stainless insides of the 1300cc boschs?
Is there really that much of a differance between the standard bosch and the ids?
The ID2000 spray pattern is pretty poor and linearization becomes a problem below 1.4ms pulse width. This causes all sorts of issues with E85 from poor idle control, poor engine response to cylinder bore washing. They work but users need to understand the additonal risk...fuel dilution etc
It is my understanding that any of these Bosch EV14s need to be modified for use on liquid fuels, as they are originally gas injectors. I might be wrong, but that was my understanding.
The 1000's are fine, the 2000's are natural gas injectors.
If ID actually release the 1300's for sale (I hear they are having issues supplying them atm) they would be the best option, until then the 1000's are your best choice, with a higher base fuel pressure to bump them up into the 1300-1500cc flow area. Be wary buying from the US as a warranty from there is almost useless. (by the time you pay for shipping back to ID and wait a month for them to be returned.)
The other option is Moran injectors, not cheap but there are plenty of sizes to chose from, and they spray beautifully, but you will need a 10 micron filter for them or your warranty is void.
Any other options for slightly bigger as those morans are damn expensive
Not for E85, there are 2200cc continental/VDO injectors for petrol vehicles, but I have never seen them used, and they are a little more expensive than the Bosch 2000's last I checked with my wholesaler.
The moran injector fan/spray angle is very wide... I allways wondered if you'd get to much wetting down against the intake mani wall.
Ever seen a set in a GTR?
J.
J.
Not yet, the EV14's are the big seller, the Morans are always too expensive at around $250-$300 each, depending on size.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
