Hey all,
I just wanted to quickly clarify whether this noise I am hearing is normal or not. When I pressurize the intake using an air compressor to test for leaks, I have noticed before that I get an odd whine coming from somewhere in the engine bay. I have narrowed it down to having something to do with the charcoal canister, as when that is disconnected and the lines blocked, the sound disappears. However the sound emanates from the back of the engine bay, over near the brake booster.
Now I am totally unsure why, but when I first made this discovery a few months ago I dismissed it as being normal. Upon hearing it again, I had the thought that perhaps this isn't normal and is an issue that I should rectify.
So, here is a video of pressurizing the intake with the charcoal canister disconnected. Note no noise:
Here is another video, now with the charcoal canister connected again. Note the noise that comes in at approx. 11 seconds.
I should also point out that I have never heard the sound while driving, I guess because the noise of the car covers it up or possibly the noise doesn't occur with the engine running.
Edited by Hanaldo
Can you unplug the hoses from the charcoal canistor one at a time to isolate which part of the system is making the noise. Just tryong to think where the lines run. One to the throttle body on the intercooler/turbo side of the TB, one to the manifold, one to the fuel tank breather and one more? Cant remember and dont have my car handy lol
I'm not sure what help this is but when we pressurise air systems in trucks and trailers at work on 100 psi to release the brakes for brake adjust or whatever, the air tanks can make this sound for a minuite then the sounds goes away when they are full, it may be normal.
The charcoal canister should only ever see vacuum as the diaphragm that opens it only gets exposed to vacuum at light throttle opening due the a valve on the cylinder 1 throttle.
I've heard that sound before, and it sounds more like throttle gasket or shaft seals.
Well considering the noise is only there when the charcoal cannister is connected, does that not mean it must be related to it? I can pump 20+psi into the system with the canister disconnected and it will be dead silent.
Also Nur, and what do you mean cylinder 1 throttle? The engine is a 25 Neo, so there is no Cyl 1 throttle. I did think the noise might be related to a diaphragm that doesn't normally see positive pressure, HOWEVER. When I installed the Plazmaman plenum, I ran new hose for the charcoal canister so that I could run it a natural way. It now goes straight into the plenum through standard 1/4" hose. No valve anywhere. Is that likely to be a problem?
Where is the valve supposed to be for the charcoal canister? If I have deleted that valve without knowing it, would the charcoal canister essentially be a big boost leak?
That is the sound of air leaking past a diaphram valve im guessing the one that only opens on vacuum being present. And sounds like a fairly small amount at that. Find the valve, and inspect. Not sure about the 34 ones but 33 is the round bit on top of canister
Does anyone know where this valve is? If it is between the canister and the plenum, then it no longer exists. I've run 1/4" hose directly from the canister to the plenum, there's no valve in that line. If it is in the line between the fuel tank and the canister, does anyone know where? I can't find a diagram anywhere.
i do the same test from time to time, and haven't had that noise....just sounds like a leak to me. What's the pressure gauge doing, going down? After I replaced the leaking PCV valve mine holds pressure pretty well, no rapid drop or sound of leak like that. Other option would be to try getting can of party smoke and filling air compressor with it, then pressurising and seeing if any colored smoke coming out anywhere..?
Well the sound doesn't come from anywhere near the canister. Its definitely over near the brake booster.
the inline chechvalve on booster line? remove/block booster line and test?
That valve is fine. The noise isn't coming from the brake booster, just some where near it. I block off the charcoal canister and it goes away, has to be something to do with that, surely?
That is the solenoid for the charcoal canister, so it only sucks air from the tank when there is vac in the manifold. Perhaps it's leaking? It looks like the same part my car uses for a stock boost controller.
  • Like 1
Hmmm... I imagine it won't be an easy part to find :/ I don't really want to block off the charcoal canister though. Would definitely much rather keep it.
I doubt this is the cause of my power issues anyway, it's barely leaking at all :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
