I have a stock rb20det with a stock turbo down pipe to the ground. No exhaust.
Would this upgrade be a bad idea?
http://www.ebay.com.au/itm/400455487571?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Feel free to voice opinions, and other possible options, however I am on a budget
https://www.sau.com.au/forums/topic/431577-r31-rb20det-track-car/
JJR bell mouth from Justjap will set you back around $170 from memory. It is a much much better choice.
That depends on what you're doing for engine management and fuelling. I will ignore the 10 psi part for the moment.
In general, on an RB20 that is running standard everything and maxing out the standard turbo, you 'll get to 160 - 170rwkW and the injectors will be maxxed or close to it, the AFM will be reading 5V or close to it, the turbo will be at 14 psi and running on borrowed time before dying. If you put on an RB25 turbo it will make the same power at a bit less boost, because the turbine housing is that little bit bigger. You might reach the same power levels and hence the same injector duty cycle and AFM voltage at only 12 psi. So no change. Maybe you'll scrape a little more power out of it if there is still some room in the injectors and so on. 180rwkW is a fairly common result.
To get any more you need to be able to keep up with the fuelling and really need to be able to tune the ECU. And then you're pushing an RB25 turbo up to 14 psi where it is just as likely to go bang as any other Nissan ceramic turbo. Maybe it will be a little less prone to self destruction running 14psi into an RB20 than it would on an RB25 because the shaft speed will be a bit less to make the smaller amount of flow at that boost. But it really is a game of chance when you wind them up.
Would I do it. Yep. Would I expect the world to be a different place afterwards? Nup. On 10 psi it will make a little more power than the RB20 turbo, again maybe 10 rwkW, maybe less. You really need to add some boost to get a sizable benefit (with increase in risk of course).
Edited by GTSBoy
  • Like 1
This is what I know of the engine in my drift car
Rb20det
Huge FMIC, too big IMO (bought it that way)
Hks bubble air filter (brand new insert)
3" bell mouth dump pipe as stated above. (Not installed yet)
Some sort of resistor wired up to something near the intake that supposedly makes the car think its running at 30 degrees so it pumps more fuel in :/ (previous owner)
I know nothing about how to tune an ecu.
I'm not looking for huge power. Just another 15-20kw to make a little more drive to make it easier to link corners.
Note: I have two turbo options, option 1: rb25 turbo $200 or option 2: r34 op6 turbo for $300
Or which direction should I go for that extra 15-20kw that will be the cheapest overall
The Nistune is nice and cheap too.
Fuel pump and injectors might help.
Im getting 180 kw safe and reliable with all that on 14 psi rb25 turbo.
Now the turbo is the weak point. Cant go any more boost.
JJR steel bellmouth works good for me, dont go stainless, its a waste of money.
Op6 turbo is good cos when you want to hi flow, it has the good housing.
But think..... if you want cheap, you get the tune once.
That means working it all out, install all the bits, and get the Nistune.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
