Happy Laps - Queensland Raceway 27-10-13
  • Replies 288
I'm will most likely not be making it to this guys, had someone run up the back of the skyline today and insurance isn't even looking at the car until the 16th so I doubt I'll have it by the 27th
Bring the hire car out. Useful bit of information in the post below.
For those unfortunate enough to find themselves in a similar situation and without their car whilst its been repaired, I was not aware but its a legal obligation for the party at faults insurer to pay for a hire car whilst yours is being repaired. Acorn Rentals is a company that handles this for you. A simple online form (providing you have full details of the party at fault) and they do the rest. Don't get tricked in to renting one yourself (if a hire car is not included in your policy) and then sending the claim to their insurer and hope (pray) they reimburse you!
I am out now guys, just found out the misses has planned a dirty weekend away ;)
well that's too bad for you :P
also........................................................IN...........................AND PAID :laugh:
  • Like 1
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
